Backhoe Who sells aftermarket backhoe thumbs??
   / Who sells aftermarket backhoe thumbs?? #1
gordon21
Lake Lure NC
JD 790
Can someone recommend a supplier who sells thumbs that could be retrofitted to a JD #7 backhoe that is used on a 790 and about half a dozen older JD models in the same size range. I would want a non-hydraulic model with 1-3 fixed positions. I remember seeing a post where the thumb had a shaft with a couple holes to adjust the angle/position. Something with pins where the thumb could be removed and leave only a couple small mounting brackets would be ideal. I can't weld, so whatever I buy needs to be a complete kit that I will take to a welder to attach.
I just ordered the hoe and it should arrive in a couple weeks and be ready. It would be great if I could get this work done at the dealer before I pick it up.
   / Who sells aftermarket backhoe thumbs?? #2
Recently I saw, either in this thread or in the Kubota owning and operating, a thumb on the bh of a BX23 or BX24. The thumb had continual adjustment by using a threaded cylinder and heavy threaded rod, much like an adjustable top link. If I can find it, I'll return here and post a link.
   / Who sells aftermarket backhoe thumbs?? #3
When I got my JD 110 TLB last December, JD had a non-hydraulic thumb just like you are describing.
I saved my pennies and just ordered an Addington hydraulic thumb, after reading about problems with the JD hydraulic ones. http://www.addingtonequipment.com/thumbkits.html
I do not know if the JD mechanical thumbs have the same problems the hydraulic ones have.
   / Who sells aftermarket backhoe thumbs?? #4
Why not visit your we have everything store, eBay? Here's one I found on a quick search backhoe thumb
Thanks PineRidge. That is exactly what I was looking for and the price is right too. Under $300 delivered and I am guessing about $50 to get it welded. Add another $15 for 2 cans of JD green paint and I am set to go for $325
   / Who sells aftermarket backhoe thumbs?? #6
Glad to help, don't forget to post pictures of your progress.
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
(APPROX 72) UNUSED PALLET OF LANDHERO WHEEL STOPPE (A51248)
(APPROX 72) UNUSED...
2023 Chevrolet Express 2500 Cargo Van (A51692)
2023 Chevrolet...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
