gordon21
Veteran Member
Can someone recommend a supplier who sells thumbs that could be retrofitted to a JD #7 backhoe that is used on a 790 and about half a dozen older JD models in the same size range. I would want a non-hydraulic model with 1-3 fixed positions. I remember seeing a post where the thumb had a shaft with a couple holes to adjust the angle/position. Something with pins where the thumb could be removed and leave only a couple small mounting brackets would be ideal. I can't weld, so whatever I buy needs to be a complete kit that I will take to a welder to attach.
I just ordered the hoe and it should arrive in a couple weeks and be ready. It would be great if I could get this work done at the dealer before I pick it up.
