Who plugs tires?
   / Who plugs tires? #41
I think the quarter turn is to wrap the excess around the tool inside the tire so when the tool is pulled out there is a ball on the end to seal against the inside of the tire.
I suspect the goal is also to put the two halves of the loop between the cords of the original penetration, as they're pulled back into the hole. Four cords fill a round hole better than two, as all components try conform to each other.
   / Who plugs tires? #42
Have had several tires plugged through the years but actually prefer the patch method. Got a screw in an 8 ply trailer tire last year. Had it patched instead of plugged. Considering the stresses put on a tandem axle trailer tire with lot of twisting on tire thought this was a better route
   / Who plugs tires? #43
I've had good luck with plugs.
Had a work truck with a slow leak. Drove to the approved shop twice to have it fixed to be told to leave it and they'll call when done. NOT.
In to work early before anyone else, brought my personal plug kit and never had an issue with it again.
   / Who plugs tires? #44
I've been plugging tires since I was 16 years old, I'm now 57 and out of hundreds of plugs I only had 1 fail and it failed within a few miles of the house, my fault as the nail was right in the edge of the sidewall and had to much flex for the plug to do it's job.
   / Who plugs tires? #45
Ive never had luck with plugs. I got a flat on my side by side and pulled out my old plug kit. The plugs were still real sticky. I plugged hole. A few days later it was flat again. I took tire to Les Schaub tire to get fixed. All they did was replug it and charged me 21.00
A week later, flat again. I took it back and made them pull tire and patch. We will see if it holds. This was done last tuesday.
years ago took a garden tractor tire to a Les Schwab, asked to be "patched", they plugged it, they told me it still leaked and charged me.
   / Who plugs tires? #47
I've never plugged a tire. Got tired of taking the wife's car to the tire shop and purchased a plug kit, and we haven't had a problem since.
   / Who plugs tires? #49
I've done that too. Steel belted radials can provide extra challenges trying to get the reamer through the belts too. I've had very good success over the ages with tire plugs.
Never had to do that. Guess the Safety Seal reamer is stouter than others.
The glue helps the plug slide into the hole, and I figure that it will help seal and help the plug last longer. Sometimes the glue makes it difficult to withdraw the split head tool without pulling the plug back out.
Next time, I'll consider burning the stubs to vulcanize, as my SxS won't get the tire hot enough to do the job.
If the lube in the Safety Seal kit isn't slippery enough, I doubt that glue would be any better. Besides, the lube and glue may not play well with each other. And the glue may not be compatible with the plug.
Please note that my suggestion to burn the ends of the plug was for Safety Seal plugs. I have no idea how it might work (or not work) with other brands.
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
CATERPILLAR CB24B SMOOTH DBL DRUM ROLhttps (A52705)
CATERPILLAR CB24B...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
2007 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52705)
2007 GENIE...
2020 Isuzu NPR Heil 8RLDB 8CuYd Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
