Oil & Fuel Who makes Kohler oil?
   / Who makes Kohler oil? #11
Without an answer to the original question. Who makes this stuff for Kohler?
From what I've searched, it looks like Kohler sources their bottled oil from Warren Oil/Coastal/Unilube. Same as Walmart and lots of house brands. Good oil, nothing special if that's the case.
Joel
Cool. Thanks.
   / Who makes Kohler oil? #13
Hey DN,
I was at an auction Saturday and an 1872 with a 60" deck went for an even $1000. The good news, it was really clean, recent repaint, the bad news, 1800 hours and it didn't run.
In general things went for a lot more than I expected.
Curt
   / Who makes Kohler oil? #14
Well Bob it's your iron. I don't think you'll find the same amount of zinc and chromium in Castrol that you will in Harley oil. Air cooled engines need them both. Plus I would rather buy Harley oil than risk engine damage. Here in La heat is a big issue and I want the best protection. Castrol is great for water cooled applications. I use it in my GMC Sierra.
I misspoke. Air cooled engines count on the Zinc and Phosphorous for wear protection. Use oils that have at least around 0.12% . These properties are being reduced and replaced by Boron which is suppose to do the same thing. As far as the Kohler oil question Kohler might tell you. I think it would be more important to ask how much ZN and P it contains..
Hey DN,
Curt
Sold mine for $1000. It was clean(not painted) and ran well. I bought it for $1500 6 years ago. GOt my $$ worth. Coulda got more for it if I tore it down and painted it but I don't have the time for that. I think I did well on it ...............and the new one($2995!). As I see it I got a new 2554 for $1995 ;)
   / Who makes Kohler oil? #16
... I think it would be more important to ask how much ZN and P it contains..
That's a fact. Heavy-duty/diesel engine oils with high levels of Zn and P are readily available just about anywhere if that's what you are looking for. Product data/specs sheets are also readily available for most. You'd be hard pressed to find a product data sheet for Kohler engine oil.
Joel
I guess we're back to Rotella oil :)
   / Who makes Kohler oil? #18
Just listen to the manufacturer, and don't put Rotella in it until it has 50 hrs on it.
AJ
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2005 Suzuki King Quad 700 Fourwheeler (A57453)
2005 Suzuki King...
2025 CFG H12R Mini Excavator (A56857)
2025 CFG H12R Mini...
2161 (A58376)
2161 (A58376)
XCMG CV83PD (A53317)
