Oil & Fuel Who makes Kohler oil?
   / Who makes Kohler oil? #11
Without an answer to the original question. Who makes this stuff for Kohler?
From what I've searched, it looks like Kohler sources their bottled oil from Warren Oil/Coastal/Unilube. Same as Walmart and lots of house brands. Good oil, nothing special if that's the case.
Joel
Cool. Thanks.
   / Who makes Kohler oil? #13
Hey DN,
I was at an auction Saturday and an 1872 with a 60" deck went for an even $1000. The good news, it was really clean, recent repaint, the bad news, 1800 hours and it didn't run.
In general things went for a lot more than I expected.
Curt
   / Who makes Kohler oil? #14
Well Bob it's your iron. I don't think you'll find the same amount of zinc and chromium in Castrol that you will in Harley oil. Air cooled engines need them both. Plus I would rather buy Harley oil than risk engine damage. Here in La heat is a big issue and I want the best protection. Castrol is great for water cooled applications. I use it in my GMC Sierra.
I misspoke. Air cooled engines count on the Zinc and Phosphorous for wear protection. Use oils that have at least around 0.12% . These properties are being reduced and replaced by Boron which is suppose to do the same thing. As far as the Kohler oil question Kohler might tell you. I think it would be more important to ask how much ZN and P it contains..
Hey DN,
Curt
Sold mine for $1000. It was clean(not painted) and ran well. I bought it for $1500 6 years ago. GOt my $$ worth. Coulda got more for it if I tore it down and painted it but I don't have the time for that. I think I did well on it ...............and the new one($2995!). As I see it I got a new 2554 for $1995 ;)
   / Who makes Kohler oil? #16
... I think it would be more important to ask how much ZN and P it contains..
That's a fact. Heavy-duty/diesel engine oils with high levels of Zn and P are readily available just about anywhere if that's what you are looking for. Product data/specs sheets are also readily available for most. You'd be hard pressed to find a product data sheet for Kohler engine oil.
Joel
I guess we're back to Rotella oil :)
   / Who makes Kohler oil? #18
Just listen to the manufacturer, and don't put Rotella in it until it has 50 hrs on it.
AJ
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
Central Machinery Horizontal/Vertical Bandsaw, S/N 366852447, 120 Volt (A59076)
Central Machinery...
MOBILE BBQ GRILL (A52708)
MOBILE BBQ GRILL...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
2019 CATERPILLAR 259D SKID STEER (A52709)
2019 CATERPILLAR...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
