Oil & Fuel Who makes Kohler oil?
   / Who makes Kohler oil? #1
diesel_nut
Tennessee
~'88 1872(sold); '08 GT2554
Anyone know?
Was thinking if it was just(eg: Valvoline xxxxxxx), why not just use it. Would have to be less not being repackaged for Kohler(sorry Kohler ;) )
I did a Google search and NOTHING comes up for that....down to about 5 pages deep.
   / Who makes Kohler oil? #2
Doesn't the spec just call for a 10W30?
The old Cubs needed that low ash straight 30, but I believe the manual on my 52 just calls for 10W30.
Curt
You are correct. I am just curious ;)
   / Who makes Kohler oil? #4
Oil for water, air and forced air cooled engines are all different. Small forced air cooled engines run hot so their oil has different additives. I use the recommended oil especially during warranty period. I use Kohler oil in my CC and use Harley oil in my bike. Harleys' rep is at stake with their oil and so is Kohlers..
If you want to save a couple of bucks find an oil that specifies that it is for small engines. I know Sears has it.
I realize that. I'm just curious as to who makes their oil.
Locally we have a plant that makes oil filters. The EXACT SAME filters come down the assembly line and some of them are called Brand X and some are Brand Y. The only difference is the labels, the name on the box and the cost on the shelf.
There's no need to pay more just because it says Brand Y on the box....if there is no difference.
Same thing with "Harley" oil. They don't make the oil. It's re-branded something else and I know because it says the "Holy Grail of over-hyped brands" on it you pay a LOT more for it. Reputation? I seem to remember the letters........... AMF :)
   / Who makes Kohler oil? #6
I just got my 1958 Harley FL running after 19 years and put genuine HD oil in it. It was over $6 a quart and no discount for buying the gallon containers. I think next change I'll go back to Castrol 20W-50 which I used for years with no problem. I can get it at Walmart's for $2.50 a quart.
Bob B.
   / Who makes Kohler oil? #7
Bob B.
Well Bob it's your iron. I don't think you'll find the same amount of zinc and chromium in Castrol that you will in Harley oil. Air cooled engines need them both. Plus I would rather buy Harley oil than risk engine damage. Here in La heat is a big issue and I want the best protection. Castrol is great for water cooled applications. I use it in my GMC Sierra.
   / Who makes Kohler oil? #8
To each his own. If you feel better using HD oil then that's the way to go. Oil is cheap compared to an engine. I've owned this Harley for 46 years and probably used HD oil less than 25% of the time. I'd be willing to bet that the Harley oil is probably manufactured by one of the same manufacturers that supplies oil to Walmart. All motor oil has to meet certain standards before it can be labelled. That's why Cub Cadet doesn't recommend any particular brand of oil. An old WWII plane I owned had a 670 cu in air-cooled radial engine and I used Esso (Standard Oil) 60w motor oil in it (17 quarts).
Bob B.
   / Who makes Kohler oil? #9
Well Bob guess we won't lose any sleep over our choice of oil.
I don't put a brand in the engine, I put the oil that contains the right properties for the application. I just happened to start on HD when my RK was new and never switched. It only cost me a little over three bucks by the case the last time I bought it. Have three cases in the shop. It's cost plus for me.
I think we have kicked this ball around enough.
Without an answer to the original question. Who makes this stuff for Kohler?
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A57453)
2004 Freightliner...
Komatsu D39 PX Crawler Dozer (A57453)
Komatsu D39 PX...
15 35ft. Commercial Black Metal Light Poles (A56858)
15 35ft...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 International DuraStar S/A Reefer Truck (A55272)
2011 International...
