sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 5,885
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
I needed to be able to move stuff around and since I don't have a FEL, a boom was the next best thing. I used a couple old pieces of 3" I-beam scabbed together and welded. My FIL pulled a sideload on it and bent it, so I went to build another one. Newer single piece and a upright from a bush hog and I was back in business till I went under a low oak limb with a load on it, and squashed the uprights. Installed heavy duty bush hog uprights, with reinforcements and it's great. I wanted to set some steel trusses, so I welded on a 2x2 square tubing extension and it works fine. I do wish I had added the last section on a pivot, with a cylinder so I could control the last section better, and be able to get closer to the ground thereby adding to the height of full extension.
Another way would be to put a small 12v or hydraulic winch on it and a roller at the tip, but that takes a little more time than I originally invested in my single action boom pole.
The main drawback to mine now, is I can't get it on the tractor by myself due to the added weight. I have to have someone around to put the pin in when I get it into position. Another thing, most smaller compacts don't have the lift capacity of my ag tractor, so if anyone decides to build their own, watch the weight if your tractor isn't a monster. I can probably solve the installation problem by suspending the boom in position, just haven't tackled that yet.
David from jax
David from jax
