Who made this??
/ Who made this?? #1
traderjh
I have a blue rotary mower with no ID on and the gearbox has gone out. The gearbox does have an number of 1427 91010H. The shaft has a number of 103010611j6, which looks like a case #, but does not come up in their system. Any ideas??
Jim
/ Who made this?? #2
How about a picture of the mower and closeup of the gearbox. Would certainly help get it identified.
Andy
/ Who made this?? #3
yep.. pics will help... my claravoyance is acting up with all the rain and lightening here in florida this season.. ;)
soundguy
/ Who made this?? #4
Google the numbers...You never know what you will find.
/ Who made this?? #5
google finds this post pretty quick!
soundguy
/ Who made this?? #6
Since I have several old bush hogs out back, and two of them are blue, I might be willing to go out and take a look provided I knew what I was looking for. I also add that a couple of pictures would do wonders for identifying the gearbox.No way am I going to climb around those things looking for a number to match unless the picture closely resembles it. I would also be hesitant to do it, considering you may be located halfway around the world as shipping might be more than the gearbox is worth.
David from jax
/ Who made this?? #7
Jim, get out your ruler/tape and measure the holes (size and distance between) where the gearbox mounts to the deck. Go to a nearby TSC and measure the same dimensions on one of their gearboxes. I know Howse and King Kutter use 40 hp gearboxes that are interchangeable because I swapped one from a Howse to a King Kutter.
I say all this because if you cannot ID the cutter, even finding the brand might not be much help. There may be no parts available. This is the best advice I can give without a picture of the cutter showing specific details like if it has a stump jumper and how many teeth are on the output shaft going inside the stump jumper. I have an old mower with a good gearbox and mangled blades. The spline is 11 teeth, a bit of an oddball. You just never know. When an old mower like this breaks, it's sometimes better to haul it to the scrapyard and go buy a new one or a used one of known brand with parts support.
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
2019 Polaris Ranger Crew XP1000 4x4 Utility Cart (A61572)
2019 Polaris...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
John Deere 5045E for sale
John Deere 5045E...
