Who has an air compressor with a phase converter.
   / Who has an air compressor with a phase converter.
I dont remember the motor I used. I think it was a marathon. But that dont really matter.
It was a 10HP 3450rpm motor. Same as the 3-phase that came off but just 240v single phase.
Forget all the talk of changing pulleys. I only was contemplating that because the airend (compressor head) is the SAME joy used on 3 different models. Ranging from 29 cfm when paired with 7.5hp, 40cfm when paired with 10hp and 60cfm when paired with 15HP. The ONLY difference in the three compressors other than more HP was changing pulleys to make the pump spin faster.
I was gonna drop to 7.5hp and change pulleys to basically have a TA007 compressor @ 29cfm. Because 7.5HP motors were cheaper.
You could go the other route and get a 15HP motor and spin the pump up to get 60cfm. Thats all the MFG did for their TA015 model.
And my 3m25s was from 0psi to 110
   / Who has an air compressor with a phase converter. #32
3m25s is ~23cfm. What kind of inrush amps are you measuring? What size breaker are you running it off of?
Not sure what inrush is.
once running....at little to no pressure....it pulls ~20a. Then creeps up just a tad above the motors FLA rating (which is 38 or something)....and when the compressor kicks off at ~110-115psi it is 40a. But it is only above the FLA rating for maybe 15 seconds. (as pressure increases it requires more power). 1.15SF motor this shouldnt be an issue.
Startup isnt alot either though. The compressor starts "unloaded".....then it gradually loads to start making air.
I dont know the proper way to calculate. But if you convert PSI to ATM's....figure cubic feet of air....and divide by time......it just doesnt seem to work on any compressor I have calculated it with. And when I was talking to some compressor engineers, they were explaining that it wasnt just a simple equation like that, but dont really remember why. But they also pointed out that compressors have a HIGHER rating at 40psi than they do at 90psi. And the simplistic equation doesnt account for that, so there is more too it.
I dont doubt that I am running LESS than the MFG claimed 40cfm. Again, intake and separator filter are in need of replacing. But there is also a good delay at startup while things are running but the compressor isnt "loaded".
I know I am not being much help. But if you NEED a minimum of 30cfm.....what PSI is that at. I wouldnt be confident that even a NEW 40cfm screw compressor would be what you want. Dont want to have issues everytime a filter is a month old, or as things start to wear
   / Who has an air compressor with a phase converter. #34
Actually this helps quite a bit. Inrush is basically startup current. But on a compressor it is the end of the cycle. So you have answered that.
I used a simple online compressor CFM calculator, so the 23Cfm is likely on the low side. I expect the formula is complex. I need 30cfm @ ~100psi average.
Borrowing a big piston compressor this week to find out what we really need. It sounds like 10HP is probably the bare minimum. So we may need to consider a 15HP motor. 40A, I think we can handle, but is nothing to sneeze at either. Of course 15hp is a lot more current, and I have not yet seen a 15HP single phase motor. A buddy is upgrading from a 15HP variable speed, so we might buy that. Your experience and answers have been very helpful. Thank you.
If you hook up the compressor to to an RPC for automatic start, like to hear your results on that. We have a separate RPC we may run a 3Ph compressor on instead of converting one to 1Ph. But it will need to be auto start. I don't want to leave the RPC running all the time just to cycle the compressor.
   / Who has an air compressor with a phase converter. #35
I don't know if it has been mentioned. Why not go with a freq drive? It's a much better although more fragile way of making 3 phase with single phase and you don't have the crazy high inrush currents as with a simple RPC. But, you need to DERATE the freq drive when using single phase AND make sure you get one that will even do that. Some will not work with single phase. I converted a friends lathe and mill over to freq drives and he just loves the speed and direction contol.
   / Who has an air compressor with a phase converter. #36
This is a VMC, with a 20HP spindle and a zillion other motors. RPC is the only option or pay $$$$$ to have the local utility bring 3ph down our driveway. 10 yrs ago that was ballpark quoted @ $10K. Expect it is at least double that now. We have some pretty serious energy issues here in Cali. Both Nuclear plants have been shut down permanently by fools who seem to be happy to pay one of the the highest energy rates in the country. And we now have a time-of-day Rate structure.
   / Who has an air compressor with a phase converter. #37
Apparently, here, you can't afford three phase service unless you are a big user. The delivery charges are very high.
   / Who has an air compressor with a phase converter. #38
Several of my friends have removed it from their warehouses... they were not using it and the standby charge even 20 years ago was $75 a month...
My Rotary Phase Convertor has a pony motor to start... the small motor spins up the convertor and then I flip the power switch to the convertor...
For my Bridgeport and Lathe I have a small Rotary Phase Convertor that I spin with a rope... 35 years and no issues.
One of the medical facilities had issues... I was asked to check it out... they had a rotary phase convertor and no one knew it... it was outside and running for years until if failed.
The manager called the power company and was told there is no 3-phase from the utility... then an electrician was called who bid bringing it in for 40k...
I said for 2k you can just replace what you have... boy were they happy... that was maybe 12 years ago...
   / Who has an air compressor with a phase converter. #39
That's just ridiculous, I was lucky enough that they put 3phase on the pole in front of my house a few years ago, so when I built my new shop I was able to run a 400amp 3phase service to it.
   / Who has an air compressor with a phase converter. #40
Best thing! I bought a BIG Lincoln Welder at an Auction by accident that was only three phase. I built a nice 10HP 600 Volt phase converter. Then got a drill/milling machine. What a pain to stop and start a phase converter. I sold everything 600 volt and bought a Lincoln 220 volt MIG. I don't even know how you would stop and start a rotocon for a compressor.
Does that welder use two or three live lines ?
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
2007 GMC W4500 Landscape Dump Truck (A55788)
2007 GMC W4500...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
2017 Chevrolet Sonic Premier Sedan (A55853)
2017 Chevrolet...
20'x20' High End Carport (A53316)
20'x20' High End...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
