White 2-62
/ White 2-62 #1
mtnxtreme
Can anyone tell me if a White 2-62 is indeed an Iseki, what is the hp, weight, where was it made, what kinda motor. Are they any good? Is the 4wd version any good?
Thanks
/ White 2-62 #2
According to tractortips.com its a White manufactured with an Izusu engine. It could still be an Iseki, they use Izusu engine in their larger tractors. The Iseki guru is from the land of Oz;
Puddingsworld
Tractor Specification
Make: WHITE FWD/REV Standard: 20/4 Hitch Lift:
Model: 2-62 FWD/REV Optional: Hydraulics-Type:
Years Made: 1980-1981 MFWD-STD/OPT: OPT HYD-CAP: 3.5
HP-PTO: 61.46 Tires_SD/OPT: 7.50-16 Tires-STD Front: 10.5
HP-Engine: Tires-STD Rear: 16.9-30 HVD Std Outlets:
HP-Drawbar: 51.6 Wheelbase - Inch: 99 Cooling Capacity: 5
Engine-Make: ISUZU PTO Type: IND Fuel Tank Capacity: 27.5
Engine-Fuel: DIESEL PTO Speed: 540 Cab-Std A/C, ROPS: OPT
Engine-CYL(s)-CID: 4/219 3PT Hitch CAT I: No Weight: 5250
Transmission-STD: SG 3PT Hitch CAT II: Yes New Price: $17,438.00
Optional: 3PT Hitch CAT III: No
tractortips.com The above specs are from this slow, clunky but handy site /forums/images/graemlins/tongue.gif
TAYLOR 2R MULTI-PASS HARVESTER (A64278)
TAYLOR 2R...
DYNAPAC CA262 VIBRATORY ROLLER (A64278)
DYNAPAC CA262...
2007 Yamaha Rhino 4x4 Side by Side Gas Cart (A64194)
2007 Yamaha Rhino...
2020 CATERPILLAR 259D3 SKID STEER (A65053)
2020 CATERPILLAR...
PALLET OF 14.9-24 TIRES & WHEELS (A64278)
PALLET OF 14.9-24...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
