White 2-135
/ White 2-135 #1
micky_webb
Does anyone on this site own a white tractor, specifically a 2-135? If not does anyone know anything about this tractor. I have been approached about buying one for a very cheap price. I know the tracors history somewhat. I think that the hydraulic pump is bad but I have been told that this particular tractor has a sump pump that is contolled by chain that could have come off by some chance. Any info about this tractor would be greatly appreciated.
/ White 2-135 #2
the main hyd pump is external mounted I think it is on the left side below the cab. The chain driven pump is internal and runs the lube system for the transmission. but it has been a while since I had a 135 apart I am not sure if the 135 has an internal pump that is chain driven or gear driven
/ White 2-135 #3
The older Olivers had the chain driven charge pump, the later White transmission differentials had a gear, bevel style, drive. The external hydraulic pump is a Vickers style piston pump. There are a few things on the pump that can be repaired, but if the main internal guts are damaged, the entire pump needs to be replaced.
Chuck
/ White 2-135 #4
Can't help you much but it sure brings back memories. Back in 76 I worked for a fertilizer plant and I put on Anhydrous Ammonia with a 2-150. I sure loved that tractor.
murph
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
CASE INTERNATIONAL 230 - 35' TURBO TILL (A63291)
CASE INTERNATIONAL...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2006 Volvo VNM T/A Day Cab Truck Tractor (A61573)
2006 Volvo VNM T/A...
4R CHISEL RIPPER BEDDER (A63291)
4R CHISEL RIPPER...
