WHINE OR SQUEAL
/ WHINE OR SQUEAL #1
John Marko
Canastota NY
international cub cadet 154
:confused:I have a international cub cadet 154 with a loader . my problem is when I start it there is a constant hydraulic whine or squeal , however when I move controls to rise or lower the bucket to noise goes away, or if I squeeze the large return line the noise gets lower pitch. The bucket seems to work ok but I don't know how much it will lift yet. the return hose is 2 or 3 times bigger that the pressure, could that made it whine? Please Help Thank You John M
/ WHINE OR SQUEAL #2
Not sure what hose you are talking about, but most all the hose are the same size except the suction hose.
The suction hose would be the only hose that you might be able to compress
Have you checked the fluid level and filters?
A hyd pressure gage would be a big help.
With no levers activated, there should be no pressure.
What is the position of the 3pt levers. Should not be if fully raised/max up, but slightly down to neutral.
If all the way up, you will hear the relief going off.
/ WHINE OR SQUEAL
Thanks for your reply. It is the suction hose . It works fine and no noise when you move levers , But you get the noise when the levers are in neutral position . You get the same noise as when auto transmission is low on fluid but the fluid level is ok. I don't understand why it makes noise in the neutral position or why the noise decreases when you squeeze the suction hose .John M
/ WHINE OR SQUEAL #4
Try and found out if your tractor has a suction screen. If it does try cleaning that. The pump is trying to pump more then it is getting.
/ WHINE OR SQUEAL
Thanks I will try that. But the suction line looks big compared to pressure line I know it is usually but this is 3 or 4 times bigger than pressure line? (Note this is not factory system someboby made it up for the loader works ok except for noise.)
/ WHINE OR SQUEAL #6
I just put a engine in a Deutz-Allis and the suction line is real big and the pressure is only 3/8 or 1/2".
Keho Super-Flow Grain Bin Fan (A64119)
Keho Super-Flow...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
Freightliner Columbia (A63689)
Freightliner...
Blue Diamond Brush Cutter (A64126)
Blue Diamond Brush...
30' X 5' CHAIN LINK GATE (A64281)
30' X 5' CHAIN...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
