While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #1
Aprillvsromeo1
Ford 1530
While bush hogging I got bogged down and it died now it won't start I disengaged the pto and put in neutral still won't crank
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #2
Are you saying that it won't crank over with the starter or that the engine won't start and run? IF it's not turning over than I would look for maybe a safety switch that the wires got pulled off by brush.
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #3
Are you saying that it won't crank over with the starter or that the engine won't start and run? IF it's not turning over than I would look for maybe a safety switch that the wires got pulled off by I would also check fuses.
I would also check fuses. I had similar happen and it was a faulty plug in the wiring harness that keep blowing the fuse.
2005 TerraGator 8104 (A55301)
2005 TerraGator...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
