While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #1
Aprillvsromeo1
Ford 1530
While bush hogging I got bogged down and it died now it won't start I disengaged the pto and put in neutral still won't crank
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #2
Are you saying that it won't crank over with the starter or that the engine won't start and run? IF it's not turning over than I would look for maybe a safety switch that the wires got pulled off by brush.
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #3
Are you saying that it won't crank over with the starter or that the engine won't start and run? IF it's not turning over than I would look for maybe a safety switch that the wires got pulled off by I would also check fuses.
I would also check fuses. I had similar happen and it was a faulty plug in the wiring harness that keep blowing the fuse.
2001 John Deere M665 (A50120)
2001 John Deere...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
(2) CAM2 HI TEMP LITHIUM COMPLEX GREASE DRUMS (A54757)
(2) CAM2 HI TEMP...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
CATERPILLAR 615C MOTOR SCRAPER (A51406)
CATERPILLAR 615C...
48" WIDE WOODEN W/ METAL RAILING (A54757)
48" WIDE WOODEN W/...
