While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #1
Aprillvsromeo1
Ford 1530
While bush hogging I got bogged down and it died now it won't start I disengaged the pto and put in neutral still won't crank
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #2
Are you saying that it won't crank over with the starter or that the engine won't start and run? IF it's not turning over than I would look for maybe a safety switch that the wires got pulled off by brush.
   / While bush hogging I got bogged down and tractor died now it won't start lights work but will not cran #3
Are you saying that it won't crank over with the starter or that the engine won't start and run? IF it's not turning over than I would look for maybe a safety switch that the wires got pulled off by I would also check fuses.
I would also check fuses. I had similar happen and it was a faulty plug in the wiring harness that keep blowing the fuse.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
2003 Broce Broom RJ350 Ride-On Sweeper (A52377)
2003 Broce Broom...
UNUSED TELESCOPIC LADDER - 3.2M (A54757)
UNUSED TELESCOPIC...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
