Which Zero turn to buy????
/ Which Zero turn to buy???? #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
I have to mow about an acre here in Maryland. Mostly flat, but lots of scattered bushes and trees, three buildings and a large garden, so there is lots of twisting and turning. Using our Husqvarna graden tractor with a 42" deck takes about two hours, and as I am getting old, bouncing around for two hours isn't as much fun as it once was. FWIW, I have about 300 hours on it in 11 seasons of use. No real problems at all.
So, I have been seriously shopping around for a bigger Zero Turn with more weight, better seat and faster mowing. Of course, 11 years use from of a residential grade garden tractor also means it is getting tired. A friend in a similar situation says a zero turn has cut his mowing time almost in half, also my goal!
Sort of come down to two choices: a slightly used (152 hours, clean appearing) Cub Cadet Zforce SZ48 Commercial series, 48" deck, which has a lot features I like, from mowing height of 5" max (there's a reason, but not important here) to true commercial grade hydraulics and motor, heavily built, good seat and so forth, which would cost me $3445 w/ tax, vs. a new Husqvarna MZ 52 (52" deck) which also has better hydraulics, a Kawasaki engine, semi-commercial build, and they will throw in a spare set of blades, filters, etc., for $4876. 4 year warranty, being new. It's just not as seriously built as the Cub, but not a big box grade machine, either.
I actually think the steering wheel Cub Cadet is better for our use, especially my wife (be nice if she would mow from time to time) and it sure seems to be better built. My concern is that in searching reviews of the Cub I came across one owner who had real problems with the drive belt idler, so bad he got the dealer to take it back. I realize that one problem, out of hundreds of machines, shouldn't be a major factor, but since I am buying used, I will be on my own IF there are issues. Right now, it runs just fine.
I have no doubt about either one being built well enough for me to potentially get another 500 hours of mowing use, and by then, if I even make it, I will be well into my 80's and not likely to be taking care of our property any longer.
So, anyone with informed opinions is welcome to offer them! Thanks in advance, Forum members.
/ Which Zero turn to buy???? #2
I have using this IMG_20170804_164619.jpg for 20 years. 900 hours. But I said for many years you can't beat a steering wheel. You will cut your mowing time alot. They do ride rougher than than a tractor. Good seat is a must. Can't comment on which to buy.
/ Which Zero turn to buy???? #3
I'm also from northern Maryland (Harford) here's my story, I have a cub cadet zforce 50 I bought new in 2007, it has 500 hours on it I replaced 2 idler pulleys and the mower drive belt. It has hydrogear z2800 hydro drives that I change the oil and filters every 200 hours, it has never let me down I mow 1 1/2 acres every week. In the fall I use a cyclone rake to collect leaves, plenty of power to pull a full load of leaves. I looked at the steering wheel models too much linkage and cables for me the lever style works best in my situation. If the zturn your looking at has a Kohler courage engine I would steer clear that motor has had its problems. If it's a command engine I would go for it. All the zturns I have driven ride rough, short wheelbase and small diameter front tires not like a tractor style that is longer and larger tires. I have cut the mowing time in half using this mower, I also went from a 60" mower to 50" and it's faster and easier to maneuver around trees and bushes, well that's my 2 cents.
/ Which Zero turn to buy???? #4
Kawasaki motor, a 4 year warranty, 4" wider, better hydraulics, I have to go with the Husqvarna. I had a lower class hydraulic and it was the first to go on a craftsman and the the JD 48" I had just didn't seem wide enough. The Hustler Fastrack I ended up with sounds a lot like the Husqvarna.
More info: the Cub has a Kohler Confidant engine, and both mowers use the Hydro-gear ZT 3100. Both have the same size 22" rear tires and 13" fronts. The Cub seat may be a bit better, but neither sports a true suspension seat. I might be able to get the dealer to assign the remaining warranty to me- it was 4 years and 500 hours on the Cub, and I am guessing it might be 2 years old, if that?? I am also thinking that the 52" deck might make more sense, but that isn't a deciding factor...
/ Which Zero turn to buy???? #6
IF you want a good riding zero turn, try a front deck GrassHopper, they ride very good.
SR
/ Which Zero turn to buy???? #7
I have never owned a Kohler engine but in the Hustler line the top of the line models had the kawasaki motor and the mid line had the Kohler engine. I drove both and preferred the Kawasaki. Have you test driven both?
/ Which Zero turn to buy???? #8
SR
Sawyer, the picture I posted above is a grasshopper in disguise and my ***** and back would tell you differently. :laughing:
Guys, I have driven them both, but unfortunately, only the Cub on grass. It was a fairly rough area, and although the "ride" wasn't cushy, I think it was better than my garden tractor. I liked the Husky, too, but it's another $1450 or so, and I don't know if it has any advantages at all, beyond the 4" of cutting width.
Like I said, the Cub's steering wheel seems like a better choice for us- my wife likes it a lot better, and anything that gets her mowing is a plus.
I didn't exclude the more commercial mowers, but they are either out of my price range, or so used that I figure they will need regular repairs/maintenance. Remember, I am searching for something that will give me maybe 500 hours of mostly hassle free use over 10-15 years, at most. Belts, filters, oil changes, and blade sharpenings are fine, but more serious repairs are not something I want to deal with.
A guy in the business tells me that now not all Kawasaki engines are necessarily built to the same high standards. Made in USA vs. made in Japan- who knows?? Yet another question.
/ Which Zero turn to buy???? #10
I doubt that the warranty is transferrable from the manufacturer but may have a dealers warranty. I would want to know why it was traded in, did the previous owner have problems with it, didn't like it etc. otherwise the specs look good.
/ Which Zero turn to buy???? #11
I looked at reviews too , to see what model you were looking at. Seems people love them or really hate em. Did you look at reviews over on Lawn Site.com.?
Look to be nice machines. I don't think if I'd be afraid of it. If it looks well maintained and the owner seems like he's "not" giving you bull.
The Cub is being sold by the dealer who originally sold it. Probably right about the non-transferable warranty. I will ask about the first owner, but getting correct information is iffy. The machine doesn't appear to have been "fixed", at least the idlers and drive belts mechanism, which is what one owner complained about on the Lawnsite- appear original. Other than an oil change (at least I hope so!) I don't think it was serviced (152 hours). Hard to tell about the blades- they're okay but not newly sharpened. Non of the normal wear surfaces show anything but dust and stray grass clippings. Seat is like new. It was stored indoors, from the looks of it. I plan to go back and find out more first of the week. I just saw it when I was looking at another mower, and decided to try it. When I looked it up later, it became more interesting.
The Husky, being new, would be factory perfect?
Update- in looking at the Cub Cadet again, and asking about it, buying it made more sense. The first owner was a young guy starting a lawn service, who purchased it in July, 2015. He traded for a more serious Exmark after doubling the number of lawn clients last year. It is VERY clean, top and bottom, with what look like new blades! The guy took fastidious care of it (young owner, just one mower, just one operator). They would have transferred the original warranty to me had it been registered as "residential" but since it was "commercial, that was only 2 years, not 4, and it is over.
Very happy with it- mowing is light years better, and faster, than with our old 42" Husky garden tractor. Only downside is noise: the blades suck the grass up, which makes for a perfect cut, but noisy. No problem with ear plugs, but my wife needs them too, if she's close by.
Might even post a photo!
(The dealer is primarily a Kubota dealer, and doesn't seem to have much used equipment for sale, and certainly doesn't promote it... that's good for used buyers, since an almost new mower was about half original price. What they do have is stored in a small garage, out of sight unless you ask.)
/ Which Zero turn to buy???? #14
One thing nice about first owner getting rid of it soon is he knew was beat. Finding out it was too small. Good luck with it. They look nice.
Update- we did buy it, they delivered it along with a full set of filters, spark plugs, etc. for a complete future service. I found that our mowing time was basically cut in half (if I slow down and do a careful job, then instead of 2 1/2 hours just over an hour) and the cut is better: the 3 blades really suck the grass up before cutting. I am glad we went with the 48" deck, since anything wider would cause clearance problems and uneven mowing over rough ground as the deck spanned dips and rises.
I also learned that since this mower is so heavy and powerful, if I hit something it gets whacked, as before the mower just bounced off it. FWIW, after I got it home and went all thru it, I was very pleased with just how clean and unused it was- I would have to blow it off, wash and dry it after each use to keep it so nice! The noise issue was solved by a good new set of headphone style hearing protectors. The old Husky garden tractor sold easily, as well, so all is good.
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
Ford Pickup Truck Bed (A61568)
Ford Pickup Truck...
Kubota SVL 95-2S Track Skid Steer (A61166)
Kubota SVL 95-2S...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
