boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,789
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
if you have a zero turn or regular old riding lawn mower, then ya next best thing most likely a "pull behind rtv / utv" rotatory cutter (brush hog) that has its own mower on it. majorty of the rtv like pull behinds have a (beh forget name) tow bar that allows ya to swing it out to one side.
this does a couple things for ya...
1. you can cut the tall stuff.
2. if you maintain the blade on it more like a finishing mower blade, you can hop onto riding lawn mower, and toss this on behind ya. and mow some extra width, when regularly cutting grass.
3. if grass is a tad tall for zero turn / riding mower, set the pull behind a little higher, for cutting, and zero turn/riding mower deck to were you want it. so ya making kinda of a double pass, in a single pass.
your higher end commercial zero turn mowers. (larger beefer engine most likely a diesel engine on it) will more likely handle tall stuff. but the issue still comes back to finishing mower blades, vs a rotatory single blade. and how the blades are driven. most finish mowers are driven via a belt. and when ya get into tall weeds, those weeds will just wrap right around finishing mower blades and clog it up and burn up belts.
you have a city size riding lawn mowers, then a beefer garden tractor, then you get into SCUT (sub compact utilty tractors), then into CUT (compact utilty tractors)
a garden tractor, with a bit more engine, more likely wider deck. if you set the deck as high as possible, and only take 1/3 to 1/2 the deck width of a cut of the tall stuff. you might get away with it. BUT!! i am going to advise remove belt shield on one side (opposite side were grass shoots out of deck), this is rather dangerous, if your foot slips down, or like, you may end loosing a foot or worse. this is so you can actually look down at the spindels / pulleys to see if they are rotating or not. this can help save your belts some, by being able to stop / turn off garden tractor, and clean out the clogged up weeds under the deck, before the belts heat up / melt and break.
riding lawn mowers kinda of a pain in rear to check the middle finishing blade / pulley to see if it is turning or not. and ya need some ears on ya, and paying attention, with some experience under ya belt. to figure out if middle blade is clogged up or not with weeds.
when cutting tall weeds, always blow crud away from what you are going to cut on next path.
the little chut were grass comes out, wire it up (bungie cord or like) so grass / weeds come out easier.
your finishing mower blades will take a beating from this. and you will most likely want "straight" finishing mower blades, there is no bends/twists in the blades. unlike mulching blades, that may have some extra twists / bends in blade.
