dannydimitt
am sick and tired of cutting the 3.5 acres out back with the 42 inch sears garden tractor , because you essentially have to go over it twice because it pushes the grass down instead of cutting it . I know if I were to open up the front of the deck with a torch and have the blades make first contact , instead of the deck it would cut fine , except the blades would also make first contact with ant hills and stobs too , and then the woosy mandrels will break . and the lightweight deck would probably collapse . Whats the use of having 20 plus HP driving the blades when the **** thing just rolls over the high grass . Durn sure don't need all that HP to cut a couple of days growth lawn .
Would like to be able to cut in one pass without resorting to the six ft single blade cutter behind my Kubota 3200 .
Any one got a zero turn that cuts , instead of rolling over ?
