Which would get better traction?
/ Which would get better traction? #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Take 2 4x4 utility tractors-same brand, HP, weight, etc.
One has R-1 Ag tires with on open front differential. The other is the same tractor, but it has R-4 utility tires and a limited slip front differential. Both have a locking rear differential.
Given similar terrain conditions, which one gets better traction?? I think the R-1 tractor, even with open front differential disadvantage, may still get better traction. What say you?
/ Which would get better traction? #2
Hook 'em up!!!
I agree that the ag's would probably get better traction, but it would really depend on the surface that your pulling on. On asphalt, the turf tires would do better, but in mud, the ag's rule.
David from jax
/ Which would get better traction? #3
I bought R4's on my new tractor and I have yet to find anywhere that they get better traction then my R1's. The R4's cut up the lawn and spin on a dog turd. I wouldn't give ten cents for them in hind sight. R1's or nothing for me.
/ Which would get better traction? #4
I would say that it would be darn close. In general R1s have about 30% deeper tread than an R4. So if you were to say that each R4 tire had a rating of 100 and each R1 had a rating of 130, then you end up with the R4s giving you a total of 400 and the R1s with a total of 390. So in my example, not only do you have a higher rating with the R4s, but you have all of your weight pulling where as with the R1s, you have 3 tires pulling and less than all the weight working for you. This is only an example and of course there are many different types of R1 & R4 tires. As I think you already know, R4s are usually thought to be of tougher material and will wear longer and carry a heaver load, but this is only an (in general thought). There are tough R1s out there, you just have to pay bigger $$$$ for them.
/ Which would get better traction? #5
I had a Kubota B2150 with a 24hp engine, FWD with R1's. I now have a MF 1433v with a 33hp engine, also much heavier, FWD with R4's. I bush hog, plow, run a disc, etc. All in the grass/dirt. The R4's on my MF have spun when the Kubota R1's would have still be moving the tractor in similar conditions. It surprised me when it first happened. I would much rather have R1's, but the tractor was used when I bought it and that is what it had. Too expensive to swap now.
/ Which would get better traction? #6
The one with R1's would get better traction. The open differential isn't that much of a disadvantage, not nearly as much as the R4's.
/ Which would get better traction? #7
Im not real sure of that... IMHO the surface would play the biggest role. IF open diffs on tractors work the same as 4x4s (PU/jeeps etc) do the power is applied to the front wheel with the least amount of traction. With that in mind I believe the tractor pulling at all 4 wheels instead of 3 would most likley have the advantage unless the surface was real muddy..
/ Which would get better traction? #8
I wish the pictures off cheesey cell phone camera had came out better of my tractor against my buddies highly modified jeep :D
After a bit of trash talking ;) my buddy insisted his jeep would out pull my tractor, him having lockers front and back gave him a bit of advantage. So to level the playing field I picked up a full bucket of sand with the FEL. We hooked the strap up and I drug him around the sand covered hard gumbo field like a play toy:D :D
After listening to him complain about the sand I politely dump the sand and hooked back up to him... To my amazement it was a draw, He was spinning all 4 13.50" x 37" Baja Claws wildley I was in double low barely spining 3 tires, and yes I do have the dreaded R4's...
Heres some pics of the jeep and where not to hook the strap to...
/ Which would get better traction? #9
An LSD in the front is only to be helpful if there is differences in the tractive surface beneath the front tires. If you bias the course so there is ice on one side and pavement on the other, the LSD equipped machine will win. Otherwise, on anything resembling normal dirt, I would think the R1s will whup on the R4s.
Builder, in the construction field, those R4s you like are ideal. Half the time, you need the floatation and the other half you need the toughness. For guys like me who don't use the tractor to make a living, having the option to leave the tractor in the barn when the conditions are such that I'll tear things up or something means R1s are the best bet.
/ Which would get better traction? #10
If you removed the front driveshaft from the one with the R1's, then they would each develope about the same traction. R4's are not designed for traction by any stretch of the imagination. They are designed for industrial uses on hard ground or pavement. Off of that they are much closer to turf tires in traction ability. If you want the most traction out of your 4wd tractor, then R1's are the only way to go. R4's will give you little if any traction advantage over a 2wd with R1's except for front loader use. A 4wd will out work a 2wd on a front loader no matter what the tires.
/ Which would get better traction? #11
Very Large Dog. :D
Chuck K. said:
Hooking a strap to the cage is wrong on so many levels, I don't even know where to begin.
I completely concur with this statement. The only time a limited slip or locked diff will help a lot is if the vehicle is off camber, or if there is a traction differential between left and right side. I vote that in most surfaces, the open front R1's will out traction the limited slip R4's.
/ Which would get better traction? #12
Agreed, but he did prove his point to a certain degree that the modifications to his factory cage did strengthen it quite a bit... The wheelie and pulling the H3 off the sand pile did no damage to the cage.
Does any SCUT or CUT tractors come with locking front diffs. ?
Is a locking front diff. available for my tractor???
/ Which would get better traction? #13
I would be surprized if any of the small machines have them. A locked front diff would be subject to a great deal of internal stress when turning, not to mention the slippage between the tires and whatever happens to be beneath them at the time.
A limited slip front diff would still be very hard on things, but not as much as a truly locked one.
They used to be available on some early 4x4 trucks and SUV forerunners, but they were very tricky to control when the torque switched sides during transits over variable surfaces. I think some serious offroaders have installed them for swamp and mudrunning, but they are not, to my knowledge, available from anyone as a factory item.
/ Which would get better traction? #14
Selectable front diff lockers are a factory option on the Jeep Wrangler Rubicon edition. They were also a factory option on mid 90's Toyota FJ80 series Landcruisers. And you're right, turning is a bugger with the front locked in.
They're also standard on Unimogs and Pinzgauers, but that's a whole different world.
Heck yeah. The Kubota M6800,8200, 9000 and the newer 7040, 8040 9040 have them. They are "automatic" limited slip. The Kioti DK65 even has one that locks the front diff with a pedal.
In my world, they are small machines. Maybe they're big to you guys....
I've installed ARB front lockers in some of my 4x4 trucks I've had in the past. Gotta be careful with them.
/ Which would get better traction? #16
tessiers said:
I bought R4's on my new tractor and I have yet to find anywhere that they get better traction then my R1's. The R4's cut up the lawn and spin on a dog turd. I wouldn't give ten cents for them in hind sight. *R1's or nothing for me.
Ya got it
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
2015 Bobcat T590 (A64126)
2015 Bobcat T590...
2008 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61573)
2008 Stertil Koni...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
CRAFTSMAN RADIAL SAW - 10 BLADE OUT RIP (A64281)
CRAFTSMAN RADIAL...
