Which wire under the seat?
/ Which wire under the seat? #1
Mark_60
There are two wires under the seat of my BX 2200. One has a male connector, and the other has a female connector. Which wire is for auxiliary power? Where is the best place to make the ground connection? I will be wiring in a pigtail for a 25-gallon electric sprayer.
/ Which wire under the seat? #3
If that "pair" of wires was wadded up and taped to the big loom, they are the pos and neg for aux power ... Assuming it's the same setup as my BX23.
/ Which wire under the seat? #4
/ Which wire under the seat? #5
On my BX2200 there are three wires under the seat:
1. Red - Female - Positive (switched off when key is off)
2. Black - Male - Negative
3. Blue w/ White stripe - something to do with the HST light in the dash (this wire is about 1-2" farther down the loom)
I have a wiring schematic for the BX2200 but the file is larger then the allowable 100kb to attach.
/ Which wire under the seat? #6
/ Which wire under the seat? #7
My BX2230 has a pair under the seat with same male/female connectors as yours. One is pos the other neg. They are "switched". I think the shielding is even red and black. Take a closer look. They are fused at your box on the Aux circuit depicted in your manual where it describes the fusebox.
/ Which wire under the seat? #8
2023 John Deere 6R 175 Tractor (A63111)
2023 John Deere 6R...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
UNUSED ATSPOWER ATS-SP50 50 TON HYD SHOP PRESS (A64281)
UNUSED ATSPOWER...
Unverferth 432 (A64119)
Unverferth 432...
2019 John Deere R-4038 (A63688)
2019 John Deere...
