electrycmonk
- Joined
- Nov 6, 2018
- Messages
- 212
- Location
- Near Denton, TX
- Tractor
- Satoh 370 diesel & Cub Cadet 7260 Diesel 4WD standard
I just got home from a local JD dealer that used to be a Cub dealer as well.... I have learned some new vocab but, not sure how to best search the forum with these words.....because they are so common in our language that the engine should give me nearly every thread in the forum...
Raw data:
Cub Cadet 7260 with a FEL but, no rear QD kit installed (they can have them and there "was" a kit)
The shop supervisor told me that the Cub's back then had one of these 3 systems:
1) open center
2) closed center
3) compensated center
He also said to be on the look out for the systems a) standby pressure & high pressure as well.
He said that once you know that stuff you will be able to figure out which "power beyond parts the 7260 will need to hook up to a backhoe etc.
I've tried the phone number for Cub that he gave me and the CSR is supposedly trying to find out any info and email.it to me today. He said he has an idea who might know or be able to help figure it out & that they would email me as soon as they had any info.... He then went on to say that if they hit a brick wall that he'd email me all they found and the brick wall fact so I'm not left in the dark. I thanked him for the previous call I has made to 'tech support' couldn't find there way outta the script to even think about a solution......
I found a backhoe that will fit. I just need to figure out how to get the hydraulic system adapted to run the BH with pigtails and some (likely) valves and a possible solenoid or two????
Thanks in advance folks.
And if I need to post pics of my system.ihave a few ready but, I'm trying to draw a simplified schematic for fluid from the data I have gleened so far...,.
Raw data:
1) open center
2) closed center
