Which "Type" of Grease ?
   / Which "Type" of Grease ? #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
Hi All.
I ordered a new grease gun to lube up all the zerks on my B3000 and snowblower.
Is there any particular kind of grease cartridge I should buy?
I know that there are s few different kind of greases for the Marine environment, but what about in the agricultural world?
Thanks for the input.
   / Which "Type" of Grease ? #2
This will end up like a Chevy vs. Ford argument.
I prefer 3% moly grease NLGI #2
   / Which "Type" of Grease ? #3
I think any good quality grease will be fine.
   / Which "Type" of Grease ? #5
as long as you keep it full of grease you shol;d be fine. I prefer red tacky
   / Which "Type" of Grease ? #6
Well mine is still under warranty so I go with what’s specified in the manual: Kubota Moly-lit.
   / Which "Type" of Grease ? #7
All the above are valid choices.
I'm also in the moly-fortified camp.
   / Which "Type" of Grease ? #9
Cat sells the most equipment with greased pin joints in the world. They recommend grease with minimum 5% moly. Sticks great even when working in water. Started using it 10 years ago when I got my mini-excavator and use it on nearly everything. I have one gun with Mobil 1 synthetic grease for high speed bearings but it separates into oil and soap not really sticking into the pinned joints like moly.
   / Which "Type" of Grease ? #10
WHAT! Are you mad! :)laughing:)
I would use whatever is in your grease-gun. In my case, it's JD 'green' stuff because the canister fits the JD grease-gun that I have.
Mind you, I don't have a, or need for, a snowblower where I live.
294 (A52706)
294 (A52706)
2015 PETERBILT 389 FLATTOP (A58214)
2015 PETERBILT 389...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
2296 (A58376)
2296 (A58376)
PORTABLE AIR COMPRESSOR (A58374)
PORTABLE AIR...
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A56857)
2014 Jacobsen AR3...
