Which Tractor?
/ Which Tractor? #1
USMMAN
Lumberton, MS
Kioti CK25
Does anyone make a 25 hp tractor with a cab? If not, which 35 hp cab tractor would y'all recommend? Thank you!
/ Which Tractor? #2
Kubota makes several 25-horsepower models with cabs.
Consider that a cab adds 600 pounds of weight and when the A/C is operating several horsepower are required to operate it.
Not good on hills.
Not good for blowing snow.
Possibly fine for pushing snow.
/ Which Tractor? #3
I just bought a kioti cx2510 cab. They also have the ck2620 cab. Kubota makes a lx2610 cab. Many others do also, but no AC in them like jd,mehindra, and tym.
/ Which Tractor? #4
Not good on hills.
Kubota makes several 25hp cab???
/ Which Tractor?
Not good on hills.
Although a 25 hp will do everything I need, it sounds like the 35 hp might be better for the extra weight and AC.
/ Which Tractor? #8
TYM does. The 3515. It also has mechanical injection, so you alleviate the ECM/DPF woes of all the other brands, which is why many stick to 25hp.
/ Which Tractor? #9
What kinds of work are you planning on doing and what kind of terrain (flat, hilly) are you dealing with?
/ Which Tractor? #10
Kioti CK2620SEH cab, 25Hp, cab, with AC.
/ Which Tractor? #11
Set in model you like with cab see if comfortable and controls are easy to use.
/ Which Tractor? #12
Think about sapping HP with AC on a 25hp tractor… I think you’d be pushing it
/ Which Tractor? #13
I can definitely tell when the AC compressor is running on my CK2620, it does make a difference on steep grades.
But it sure is nice to have, and to have the mechanical injection and no dpf.
/ Which Tractor? #14
In the past, I'd have said 35hp will run a 6' cutter where 25hp is pretty much limited to 5' and pretty much stopped there.
With DPF now a consideration, you're still free to run a 25hp engine without having to worry about DPF. If you lug an engine with DPF instead of running it at say 2,000+ RPM, it is more likely to need more frequent regens. The worry with regen is that it won't go right, and the tractor may end up in limp mode which apparently only a dealer can reset.
There is also the matter of heat in regen. Probably don't want to have regen happening in a barn stacked with dry hay.
If you actually need 35hp for what you plan to do that's one thing, but if you don't, then you have the extra hassle of the DPF system. So my advice is to think very carefully about what you plan to do and how much power you really need.
/ Which Tractor? #15
There are still some DPF tractors, where the DPF isn’t an issue. They are mechanical injection.
/ Which Tractor? #16
I agree that the OP should look at whether the tractors he is considering have ECM with a bunch of sensors that can go haywire or mechanical injection.
/ Which Tractor? #17
Yup, at least then you have options… the guy with the MF with the chronic DPF issue, doesn’t have options that the direct injection guys do… so he has no tractor
/ Which Tractor?
Basically flat. Some weaving around trees to bush hog. Otherwise, just planting deer plots, etc.
/ Which Tractor? #19
Nobody comes close to what TYM offers, when it comes to cab tractors. You can get a lot of cab tractor for under $30K. I just got this 48hp, 2,700lbs loader lift for $29,500.
/ Which Tractor? #20
Which brings up another question of whether to pay what some places are asking for 25 and 35hp cabs, when you were able to buy this 48hp model for $29,500.
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2016 Volvo XC60 SUV (A61574)
2016 Volvo XC60...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
John Deere 2755 Boom Mowing Tractor (A66285)
John Deere 2755...
