Which Tooth For Toothbar
   / Which Tooth For Toothbar #1
GIJOE
Baton Rouge, La.
MAHINDRA 3510 w/ ML112 FEL
I have been searching the forum for the last three hours and have not found the info I'm looking for. I have all the steal I need to build a toothbar except the teeth. Does anyone know what style tooth is used on the toothbars?
Thanks,
Joe
I know there are a bunch of places to buy them from, I need to know which series of shank to use.
Joe
   / Which Tooth For Toothbar #4
I ordered from Fabco, their catalog is online. I printed the page and kept blowing the teeth up on a copier until they wer full size. Then I compared them with my bucket and the steel I had for the toothbar and picked one. I already had the angle milled on the steel and ot was a bit off, but a few minutes with a 4" angle grinder in the 6 spots fixed that. Good luck, this is the best thing every for an FEL! Mine is on all summer.
moeh1,
Which ones did you end up going with?
Joe
   / Which Tooth For Toothbar #6
Joe,
Rats, I knew you'd ask, I don't recall....It was a few years ago and I probably don't have the paperwork anymore. Every bucket seems to be built different, I do recall that it wasn't the one I originally thought I would pick when I looked at the catalog online. Best I can recommend is to blow a few up and see what works for your bucket.
   / Which Tooth For Toothbar #7
I also used |Fabco teeth and adaptors!
Go online and the catalogue will have all the specs such as height, grip debth etc.
Basically you will be using a flat bar, say 3" X 3/8" to weld the adaptors onto and then you need to know your bucket metal thickness plus your existing cutting edge thickness to determine the type of adaptor you need.
Be a bit generous as I went too snug and needed to use a sledge to pound the adaptor bar into place.
On the otherhand the 5/16" 'ear bolts' have never failed in 3 years of usage.
But man what a differance in digging power.
Yep I can now scoop full buckets of rooty rocky top soil and fill stock.
Down side is back grading as with teeth that becomes a no-no, but then that is what a back blade is for, isn't it!
On the other hand with the bucket in 'full dump' and back grading mode you now hace a super 'root rake'!
Best thing since sliced bread! (for a loader bucket)
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
500 Gallon Poly Tank (A59076)
500 Gallon Poly...
