Rotary Cutter Which rotary cutter?
/ Which rotary cutter? #1
Downeaster
Eastern Maine
Kubota GrandL4330 HST
Hello all,
I am looking at purchasing a L4330 and would like to know what size rotary cutter to buy. I have some brush up to 2" diameter and think I woluld like a medium duty cutter. Is this a good idea or should I get a standard duty one.
Thanks, /forums/images/graemlins/smile.gif
/ Which rotary cutter? #2
<font color="blue"> ...I have some brush up to 2" diameter and think I woluld like a medium duty cutter... </font>
Hi Robert,
Mostly all medium duty rotary cutters = 2” cutting capacity…
However with ~34 ½ PTO HP… you are right on the border between 5’ and 6’ sizes… If most of it’s “life” will be true brush hogging 2” woody stuff… stay with the 5’ size… If mostly wide open field grass to maintain and keep down… go with the 6’
I’d go with the md rotary cutter no matter what the size you decide on, for your additional money you will get a more durable deck and side skirts, heftier gearbox and driveline, thicker and wider cutting blades…
Lastly you may consider getting at least “front deck” chains for your protection and both front and rear chains if you in a close residential area… especially getting into cutting bigger stuff…
Good luck with your search… and stay safe…! /forums/images/graemlins/smile.gif
Thank you for your advise. I will look for a 6' medium duty rotary cutter. The dealers in my area sell mostly woods and landpride. Would the Woods 720 model be a good choice?
Thanks, /forums/images/graemlins/laugh.gif
/ Which rotary cutter? #5
<font color="blue"> woods and landpride. Would the Woods 720 model be a good choice? </font>
With the choices given... I'd pick Woods MD over LP HD... /forums/images/graemlins/smile.gif
/ Which rotary cutter? #6
Downeaster
Union tractor in Union sells both Woods and Landpride I'm sure they could get you set up.
Chipperman
UNUSED WOLVERINE 7' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
Rightline LP5C-C5B0-A 42in Hydraulic Side Shift Forks and Frame Forklift Attachment (A61572)
Rightline...
John Deere 450 (A64119)
John Deere 450...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2014 Freightliner 114SD T/A Dump Truck (A61573)
2014 Freightliner...
2015 Case TR320 (A64126)
2015 Case TR320...
