Rotary Cutter Which rotary cutter?
/ Which rotary cutter? #1
Downeaster
Eastern Maine
Kubota GrandL4330 HST
Hello all,
I am looking at purchasing a L4330 and would like to know what size rotary cutter to buy. I have some brush up to 2" diameter and think I woluld like a medium duty cutter. Is this a good idea or should I get a standard duty one.
Thanks, /forums/images/graemlins/smile.gif
/ Which rotary cutter? #2
<font color="blue"> ...I have some brush up to 2" diameter and think I woluld like a medium duty cutter... </font>
Hi Robert,
Mostly all medium duty rotary cutters = 2” cutting capacity…
However with ~34 ½ PTO HP… you are right on the border between 5’ and 6’ sizes… If most of it’s “life” will be true brush hogging 2” woody stuff… stay with the 5’ size… If mostly wide open field grass to maintain and keep down… go with the 6’
I’d go with the md rotary cutter no matter what the size you decide on, for your additional money you will get a more durable deck and side skirts, heftier gearbox and driveline, thicker and wider cutting blades…
Lastly you may consider getting at least “front deck” chains for your protection and both front and rear chains if you in a close residential area… especially getting into cutting bigger stuff…
Good luck with your search… and stay safe…! /forums/images/graemlins/smile.gif
Thank you for your advise. I will look for a 6' medium duty rotary cutter. The dealers in my area sell mostly woods and landpride. Would the Woods 720 model be a good choice?
Thanks, /forums/images/graemlins/laugh.gif
/ Which rotary cutter? #5
<font color="blue"> woods and landpride. Would the Woods 720 model be a good choice? </font>
With the choices given... I'd pick Woods MD over LP HD... /forums/images/graemlins/smile.gif
/ Which rotary cutter? #6
Downeaster
Union tractor in Union sells both Woods and Landpride I'm sure they could get you set up.
Chipperman
2016 Tradewinds TG45-UL 45kW Natural Gas Generator (A61572)
2016 Tradewinds...
UNUSED WOLVERINE 60" HYD DRUM MULCHER (A64281)
UNUSED WOLVERINE...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
