Posthole Digger which post hole digger
/ which post hole digger #1
praha
Chicago suburb
Kubota L3400 gear
Land Pride, Northern tools, Leinbach e bay..........occasional use. 12".
Land pride is a double price, is it worth it? Anyone has an experience with either one of them??
Thanks ,
Joe
/ which post hole digger #2
I just got a Rhino hydraulic so I could mount it on my FEL and have forward and reverse.
Hydraulic Drive
/ which post hole digger #3
Soil type? And your expectations?
The tip is the most important thing for me. Leinbach's 12" auger is flat on the end (except for a tiny triangle tip) and will turn off target easy in grass or small rocks. I really disliked mine and I used it alot and wore out 2 or 3 tips well over 300 holes. I tried lots of different techniques but starting a hole accurately frustrated me. FWIW in clean soil it works ok. I replaced the auger with one from Tractor Supply and I like it a whole whole lot more. Its so much easier to use. For the avg do it yourselfer the gearboxes all seem adequate so tip, auger, shear mechanism, and cost are the real features to look at.
/ which post hole digger #4
I have a 9 and 12 inch auger and Mine is a TSC also. I haven't had any problems with it except shearing shearpins which is expected. There are 2 types of gearheads. Some take grade 2 5/16 X 2 1/2 shearpins while the other takes grade 5 5/16x2 1/2 shearpins. I emailed kingkutter and that is the reply I received. I've had mine 3 years and about 300 holes later no problems...
/ which post hole digger #5
Thanks ,
Joe
Sorry, can't speak to any of those, but I just came in a couple of hours ago from drilling about 40 holes in very heavy clay for a neighbors horse corral. I've had a TSC branded 3pt, PTO drive PHD (don't know who the "real" manufacturer is - Speeco???) with a 9" and 12" auger for a couple of years now. Have broken shear pins and replaced teeth - normal maintenance. Have on occasion wished for reverse and down pressure, but am generally well satisfied with its performance.
I will admit to cussin' it out pretty heavily the first time I used the 9" auger. Then I noticed that the auger had two "inside" teeth and no outside teeth. Installed the proper cutting edges and the performance improved remarkably!
Thanks guys,
well, the problem, as always, is no experience.
I don't even know what soil to expect. / just moved/....clay I think here in
Chicago suburbs. Sand with rocks in UP Michigan.
I used a hydraulic PHD a few years ago , it was an easy job. But looking for a "right" auger tip ? I'd have no clue, but I am going to do my homework.
Thanks again,
Joe
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
John Deere 5220 53HP Loader Utility Tractor (A64194)
John Deere 5220...
2017 INTERNATIONAL 4300 4X2 S/A 26FT NON CDL BOX TRUCK (A67147)
2017 INTERNATIONAL...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
(2) COLE FERTILIZER DISTRIBUTORS (A64278)
(2) COLE...
