Which model?
/ Which model?
Yes, that is the plan, to mow it as low as possible before tilling, just for that reason(so it doesn't get wrapped up).
/ Which model? #22
Usually the manufacturer of 3 point PTO devices recommend the minimum HP for the device in their specifications sheet. I am thinking you could just google the brand name and locate the spec sheet online. That might help take a lot of the guess work out of which tractor to match it up with. For instance I found that a six foot King Kutter recommends 35-50 hp. I am thinking that is PTO hp, so engine hp would be a little higher.
In the past I have set my tiller depth to one or two inches to till over a grassy area that is to become a garden. I then skim the grass off with the FEL. If the soil is a sandy loam mix or has been a garden before I would increase the depth and till. If the soil is clay, dry and tough I try to plow it first then till. Seems to be much easier on the equipment that way.
/ Which model? #23
It also goes the other way... If you put a 100hp tractor in-front of a 30hp rated implement, the big tractor can pretzel it before you even blink. Sheer pins or clutches will protect the PTO & gearbox, but not the implement as a whole, depending on the implement.
/ Which model? #24
My old tractor was a 32 hp. I run a 6 foot tiller and 6 foot brush hog with no problems at all. My ground varies from clay to sand and I usually try to go at least 5 inches deep. My new tractor is a 33 hp and I have run the brushhog in 5 foot tall weeds with no problem. Biggest factor in using anything is your ground speed. I am sure the 25 hp would run it also but the 33 hp would be better. For the price difference between the L 3301 and the L 3901 I went with the L 3301 as I could not see paying that much extra for the same tractor but with 7 hp more, My old tractor did everything that I wanted to do so my choice was easy
/ Which model?
Ivan, was your old tractor a Kubota.... or something else?
/ Which model? #26
My old tractor was a white FB 32. I bought it new in 1987 so it had some use on it
/ Which model? #27
I went the other way. I did not think trading frame size (B to L) for 1 hp more was economically sane so I went for the L3901. The biggest gain was in PTO hp 23 to 30 while engine hp went from 32 to 37.
/ Which model? #28
Great choice on the L3901. Just bought one this fall and love it. Added led light on the ROP and rim guard in the R1 tires. Got a bush hog with it and it did an awesome job in the pasture.
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63688)
2006 Cadillac...
2002 Ditch Witch 1230H Walk-Behind Trencher (A61572)
2002 Ditch Witch...
