which model
/ which model #1
trentay
Several questions from a soon to be Yanmar buyer:
Which model is the most popular 1300d, 1401d, 1500d? By most popular I mean more of them owned and parts support. Any dealers out there who want to say which is their top selling model.
Also, do any of these three tractor models have a mechanical rear differential lock and in/out of 4x4 selector?
I have the model numbers down pretty well as far as size and most features, however I have not heard about the above. Also would a hyd. top link for a three point be supported with a loader on these three models?
TIA,
Trentay
/ which model #2
I just bought my first Yanmar (yesterday, actually), and I spent about two months reading as many posts on the old yahoo site as I could, gleaning information on the smaller Yanmars, and this is the conclusion I arrived at. There is a formula to follow that goes like this.....WHAT DO YOU WANT TO DO WITH THE TRACTOR + HOW MUCH ACREAGE DO YOU NEED TO WORK + HOW MUCH MONEY CAN YOU SPEND = WHICH MODEL YOU CHOOSE. I chose the 1610D for the following reasons...to bush hog, finish mow, maintain a long gravel driveway, landscape, and add a front end loader to in the future to work on seven acres. With a budget of $5000 or less to work with to start, including some of the implements I needed, I also learned, after visiting three dealers, that I did not want a two cylinder, not because they were substandard, but simply because they make one hell of alot of racket when they run, but I've been told that they last a long, long time. I chose a three cylinder model. My next decision was 2wd or 4wd...quite a price difference, but if you want to add a fel or work on damp ground regularly, you will want the 4wd. If you can afford it, get 4wd, cause I learned from my readings, even if you don't need it now, you will want it later. Lastly, the powershift transmission was a feature I wanted...it allows shifting on the fly, and I was told that it would come in very handy when I do add a fel. Regarding parts availability, I have found that most importers have a good selection, but you might want to ask when making your final decision. You have come to the right place regarding Yannie questions. I'm a newbie, but the folks in this group are VERY helpful. Good luck, and I hope I was at least a little helpful. One last bit of advice, don't be in a hurry when you buy...be patient, visit several dealers, and take your time...you will find the model that is right for you.
HILLBILLYMAN
/ which model #3
I'd be interested in visiting a Yanmar dealer, but either I've been looking in the wrong place, or they don't exist in my part of the country /w3tcompact/icons/sad.gif. I tried using a dealer locator on one of the websites, and only 3 states showed up as having Yanmar dealers /w3tcompact/icons/shocked.gif! What's going on /w3tcompact/icons/hmm.gif??
/ which model #4
If you are using Yanmars webpage for a dealer directory you may not find many that are actually selling tractors. There are a few licenced Yanmar parts dealers that are importing used grey market machines. Most of the dealers are not parts dealers and you will have to find them via word of mouth or internet searching.
Brent
/ which model #5
Oooohhhh /w3tcompact/icons/eyes.gif. If finding a dealer is that difficult, and since I've been researching equipment for about 1 year now and I haven't run across any Yanmar dealers in my area, who would do servicing on a Yanmar tractor if I were to consider buying one from someplace? Would that be a do-it-yourself deal? Would you just go around to dealers in the area until you found one that would be willing to work on it? I wouldn't want to get a piece of equipment without having some service support available.
/ which model #7
Thanks. Much appreciated /w3tcompact/icons/grin.gif!
/ which model #9
That would be great! One of my best friends travels to Dixon all the time, so it's not too far. I'll definitely check it out. Maybe have my friend do some "Sherlock Holming" for me /w3tcompact/icons/laugh.gif. Thanks /w3tcompact/icons/smile.gif
/ which model #10
Wow, how lucky, if you have Len nearby, I think you have solved your "wheres the dealer" problem.
/ which model #11
I'm probably a little biased to my 1401D. I have never used either of the other two. The 1300D I beleive is similar to the 1401D, just has two cylinders so it would be louder and not as smooth. The 1500D is also two cylinders, but is bigger and heavier than the other two. I have however heard that some parts for the 1500 are getting scarce or not available. The 1401D is powerful for its size, quiet, reliable, uses hardly any fuel. It works well with a FEL as long as you are sane about it and don't try to bite off more than the machine can chew. If I were to do it all over again, I might be inclined to spend a few more bucks and go for a 1610D.
/ which model #12
Golfgar4,
Len has no website, but he can be reached at sheaftractor@coiinc.com for e-mail or 815-284-3226 by phone. He is one of the dealers that posted quite often over there at Yuckoo.com. He may be the closest to you of all the dealers that posted there.
I have ordered parts from him by e-mail and he is super.
/ which model #13
Ok, I have used every one of the tractors previously mentioned so I had to answer this one. Before I get started the 1500D is not getting hard to get parts for. The 1300D and a 1401D are about the same as an apple and a carrot. Totally different hood and dash, 2 vs. 3 cyl engine ECT. They do share the same rear wheel diameter (16"). The 1500D is your basic 2cyl screwdriver it does everything right and will do it day after day on a minimal amount of fuel. It has 21" rear rims and eight speeds fwd, two reverse. It is physically bigger than a 1300D or 1401D and a little heavier. All of these tractors have a differential lock. Shuttle shift models are nice but with them comes added complexity and cost. I have a dealer in WI that has a few Yanmars with loaders in stock and can service your tractor. You can visit his web site at http://svteched.tripod.com/nicksnurseryandfarmservice/
/ which model #14
Great /w3tcompact/icons/grin.gif. Maybe Len will post here soon. I'll be seeing my buddy Saturday night, so I'll talk with him about when he's going down to Dixon again. I'd just like to get info. on machines in the 30 hp to 40 hp range. I'm developing quite a library, and since you all came over from Yuckoo.com /w3tcompact/icons/crazy.gif, I've got a real interest in Yanmar - especially the cost/w3tcompact/icons/smile.gif. Look's awfully good! And I'm hearing good things from everyone who's talking about them. Thanks again!
/ which model #15
Don't just think about the cost.........think about reliability. The Yanmars have that going for them if nothing else. Then there's the parts support, the fellow owners/dealers. This little 1700 2WD has been great. I pulled an 800lb homemade woodstove up out of my basement with this thing, along with a boom pole and a rigged up 12V winch.
I turn the key, it starts, never hesitates.
/ which model #17
EFC - Thanks for the info. I visited the web site and sent an email asking for info. I mentioned that if he makes a sale, you get a finders commission!/w3tcompact/icons/laugh.gif.
/ which model #19
parts prices
Another factor to consider becides availability of parts is the cost of parts . Yanmar's suggested list price islower than the other Japanese brands. Have your body give me a call when he's coming to Dixon & I'll give him directions. I have a good selection of tractors in stock for you to look at. Contact me at sheaftractor@coiinc.com or 815-284-3226
/ which model #20
Re: parts prices
Lens12 - Thanks for the info. I'll contact you.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2016 Ford F-250 Service Truck (A61568)
2016 Ford F-250...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A61165)
2000 Volvo VNL...
UNUSED WOLVERINE SBM-12-72W 72" HYD SICKLE MOWER (A62131)
UNUSED WOLVERINE...
