Which hydraulic valve should I choose?
   / Which hydraulic valve should I choose? #1
Mcrib
Margaritaville
none
I got a different field sprayer that has hydraulic fold booms however it also has a hydraulic cylinder to raise and lower the booms and a hydraulic driven pump. The problem is I only have 2 hydraulic outlets on the tractor that I spray with. Was wondering if I could just put a valve in the system that switches between folding the booms and raising/lowering them using one outlet. I would like it to be electric so I don't have to get out of the tractor just to flip a switch. I have seen valves like this before but I cant remember what they are called, so I figured I'd ask you guys.
   / Which hydraulic valve should I choose? #2
   / Which hydraulic valve should I choose? #4
Does it use a single button switch or a rocker type switch ? I've seen both but am confused when to use each one.
   / Which hydraulic valve should I choose? #5
If you want to lock the valve in a certain position, use an on/off switch.
If you want momentary operation, use a button switch.
   / Which hydraulic valve should I choose? #6
Diverter valves generally use momentary single pushbutton switches especially when used to control grapples and 4n1 buckets. In some applications, a ON/OFF rocker or toggle switch is used, in your case either would be OK.
Other valves use a three position center off switch, but these are directional control solenoid valves, not diverters like your asking about.
   / Which hydraulic valve should I choose? #7
One side of the diverter/selector valve is a default mode with no voltage applied.
Other side is only active when you apply power.
Whichever hyd circuit you use the most should be the default.
   / Which hydraulic valve should I choose? #8
Thanks for the help, now I understand the difference.
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A52748)
GOODYEAR SET OF...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
