Which hydraulic valve should I choose?
   / Which hydraulic valve should I choose? #1
Mcrib
Margaritaville
none
I got a different field sprayer that has hydraulic fold booms however it also has a hydraulic cylinder to raise and lower the booms and a hydraulic driven pump. The problem is I only have 2 hydraulic outlets on the tractor that I spray with. Was wondering if I could just put a valve in the system that switches between folding the booms and raising/lowering them using one outlet. I would like it to be electric so I don't have to get out of the tractor just to flip a switch. I have seen valves like this before but I cant remember what they are called, so I figured I'd ask you guys.
   / Which hydraulic valve should I choose? #2
   / Which hydraulic valve should I choose? #4
Does it use a single button switch or a rocker type switch ? I've seen both but am confused when to use each one.
   / Which hydraulic valve should I choose? #5
If you want to lock the valve in a certain position, use an on/off switch.
If you want momentary operation, use a button switch.
   / Which hydraulic valve should I choose? #6
Diverter valves generally use momentary single pushbutton switches especially when used to control grapples and 4n1 buckets. In some applications, a ON/OFF rocker or toggle switch is used, in your case either would be OK.
Other valves use a three position center off switch, but these are directional control solenoid valves, not diverters like your asking about.
   / Which hydraulic valve should I choose? #7
One side of the diverter/selector valve is a default mode with no voltage applied.
Other side is only active when you apply power.
Whichever hyd circuit you use the most should be the default.
   / Which hydraulic valve should I choose? #8
Thanks for the help, now I understand the difference.
2005 Nissan Pathfinder SUV (A50324)
2005 Nissan...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2004 Airburner T-200 (A50121)
2004 Airburner...
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
Fuel Tank (A50121)
Fuel Tank (A50121)
