Which Farmi Winch
/ Which Farmi Winch #1
DLMaine01
Maine
Sold theKubota L2250DT and now have a Kubota M4900DT
I want to add a Farmi Log Winch to my Kubota L2250. Two models would work, the JL290 17-30 hp and the JL351 20-40hp. My pto hp is rated at 21. Would the JL351 work my tractor to hard? I do hope to upgrade in the future to a larger tractor but for now the 2250 is it and I have and I have lots of work for it to do. Does anyone have either of these winches?
Thanks
David
/ Which Farmi Winch #2
The 351 would follow a move to a larger tractor better, but currently the smaller winch is a better fit to your machine.
I'd buy the larger one personally!
/ Which Farmi Winch #3
Have you seen the Tajfun winch. Many of the loggers in our area use them over the Farmi. It seems better built, more features at a better price.
I know some folks that use them that made the switch and say the Tajfun is better. This is just what I have been told by users so I am not knocking the Farmi just throwing out another potential option.
Tajfun Log Winch
Good Luck!
Maka
/ Which Farmi Winch #4
I run a JL601 on a 30 pto hp Kubota. It works fine. I suggest you measure the widest point between your lift arms and match that to the largest Farmi with that distance between the lift points. Make sure the model you pick doesn't exceed the lift capacity of the 3 pt. hitch. Maybe you can go to a JL501.
Never do a side pull from the upper point if you oversize the winch based on the tractor size. A large winch can roll a small tractor in a heartbeat on a side pull.
/ Which Farmi Winch #5
This is wild, just posted about my Tajfun buy and then see this thread, look at some of the differences I posted in this forum. The Tajfun to me is more bang for the buck and I can get it the cheapest delivered.
Call Anders Rosenlund at Scandinavian Forestry 208-682-2002
http://client.forestindustry.com/forestrytech/
/ Which Farmi Winch #6
Hi Sparkkky,
I just posted this on another thread you started here. This is an article onthem. Tajfun winch article
Thanks,
Maka
/ Which Farmi Winch #7
I ran a farmi 351 for a while and traded for a 501. Both are excellent winches. It is hard for me to see anything wrong with them. Just make sure to get the one with the "dozer blade" so that you have something to pull against. I also second the note about pulling straight off the rear of the tractor. I almost took over my 4500# 2120 in a split second with about a 30 degree pull when the log snagged. The Farmi 5 year clutch warranty and ease of maintaince is hard to beat. I don't know the othe rbrand from first hand experience, but from the pictures it looks lighter duty? could be an optical illusion /forums/images/graemlins/confused.gif
Andy
/ Which Farmi Winch #8
In the like model the Tajfun is 200 lbs heavier. Look at some of the other differences I posted in my thread.
/ Which Farmi Winch #9
Sparkkky, where is the comparison? I did not see it but it has been a long day and I may have just overlooked it.
Thanks,
Maka
/ Which Farmi Winch #10
Maka, Just pointed out a few of the differences in my first post on my thread.
/ Which Farmi Winch #12
Just a thought that bounced through my air space - whew.
I noticed that the weight of the smallest Tajfun winch is over 500 lbs. More weight is better? Maybe not. Consider what your 3ph lift capacity is. Now consider the weight of the logs.
Not knockin it. I believe it is probably a good rig. Just another consideration.
/ Which Farmi Winch #13
To me a frame thats almost twice as heavy is a good thing, plus the auto band brake should be safer and easier to use and release.
/ Which Farmi Winch
Thanks for all the imput. I had not heard of the Tajfun but I have requested more info on them. Prices seem to be close to the Farmi so that probably will not be a factor. I do worry that since no local dealer handles them what about parts and support if needed? We have several dealers that handle Farmi.
The weight thing is not a big issue to me, the manual says my tractor rated at 1430lbs 24" from end of lift arms, both winches add less length than that.
And yes I have been warned about side pulls. My neighbor who has a Ford 4610(a 5000lb+ tractor) and a Farmi 601 has put it up on two wheels in the blink of an eye. Big or small you have to respect the equipment.
I will post back when I have one of them hooked to the back of the tractor.
Thanks
Dave
/ Which Farmi Winch #15
Sparkky I'm sure the Tajfan winches are good units. I prefer the brake on the Farmi. When it's engaged, it doesn't rely on friction material for holding power like a band brake. Band brakes eventually require relining. The brake on the Farmi should never require maintenance.
/ Which Farmi Winch #16
From what I understand the dog ear brakes can get stuck if you have a bind and you must move the tractor sometimes to release. Maybe someone that has used one can chime in.
Also the EGV 30A sales for $2195.00.
/ Which Farmi Winch #17
Also the safety screen, heavier cable, and the three sliders it comes with is a plus.
/ Which Farmi Winch #18
</font><font color="blue" class="small">( From what I understand the dog ear brakes can get stuck if you have a bind and you must move the tractor sometimes to release. Maybe someone that has used one can chime in.
Also the EGV 30A sales for $2195.00. )</font>
I suppose this could happen on the Farmi. Has never happened to me in about 7 years of use. I definately agree that the Farmi brake being positive engagement is safer. Farmi parts are very easy to get even though I've never needed any, my dealer stocks all wear parts. I called the distributor in New York and he told me that he could overnight any parts needed.
Andy
/ Which Farmi Winch #19
I have owned and operated a Farmi JL250, the 17-35 hp size. I purchased the winch new 30 years ago, it has been on two tractors. The clutch has been adjusted once and is in very good shape still.
The ratchet or dog style brake is very positive and to release it with a load against it you only have to slightly turn the drum and pull the release cable.
As far as the choice between the bigger and smaller one get the bigger winch if you are going to purchase a bigger tractor some day. Like others have said becareful to pull straight off the back and you can pull the front end off the ground in a heartbeat. Always watch the stem you are draging for
hang-ups and only use the tension necessary to pull the load that way when it hits an obstruction the clutch will slip and not pull the tractor over.
Randy
2019 CENTEX TRAILER 16' COOL DOWN TRAILER (A65643)
2019 CENTEX...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
Club Car Emergency Cart (A64557)
Club Car Emergency...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
New/Unused Wolverine Mini Quick Attach Pallet Forks (A65583)
New/Unused...
