Which engine would you choose?
   / Which engine would you choose? #1
Zebra5
Bronze Member
Looking at 5XXX JD Tractors. Of these engines which would you choose/avoid? 5320 3 cyl turbo, 5420 4 cyl, 5425 4 cyl turbo, 5325 5 cyl turbo.
Was the 3 cyl turbo discontinued because of problems? Or is it now in the smaller 50X5E series?
Wet sleeve vs dry, any thoughts?
   / Which engine would you choose? #2
I prefer the higher number of cylinders but would definitely wan't the wet sleeve design. The wet sleeved motors mean you can replace the sleeves (or liners with piston and rings) and renew the motor. The dry sleeved engines are cheaper in most cases.
I prefer planetary final drives which start with the 4000 series and up, and wet sleeved motors which start with the 5000 series today. The older tractors such as my 820 had planetary final drives and wet sleeves even though it is a much lower hp tractor.
   / Which engine would you choose? #3
I think if you do some digging on the 5-cylinder, there's some disappointment with the fuel usage.
Haven't read anything negative about performance or longevity, though.
AKfish
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2016 FREIGHTLINER...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2007 Trail-Eze TE80HT48DD 48ft 48 Ton T/A Hydraulic Dovetail Trailer (A51692)
2007 Trail-Eze...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
TIRE TOOLS, BUNGIE CORDS, BALL HITCH (A53843)
TIRE TOOLS, BUNGIE...
