Which Chainsaw ?
/ Which Chainsaw ?
The 365 has not been discontinued, but it did evolve into the X Torque version.
That's what I tried to tell him. That it's now called x torque. He stills says they don't make a 365 of any type.I think I'll move on .I would love to buy from a local dealer,but I've found the same 372 new on online from another dealer for much less than the $875
/ Which Chainsaw ? #42
Well, 1 dealer I called told me that the 365 has been discontinued. He offered me a 372 for $875 OTD with 24'' bar.I'm going to call some more dealers tomorrow. For some reason ,some dealers are closed on mondays
What bar length are you wanting? I will show you some to your door prices with free shipping.
Husqvarna 365 Chainsaw W/ 18in Bar & Chain
Your Cost: $660.00
Husqvarna 365 Chainsaw W/ 20in Bar & Chain
Your Cost: $670.00
Husqvarna 365 Chainsaw W/ 24in Bar & Chain
Your Cost: $680.00
Specifications for 365
Engine specification Cylinder displacement 70.7 cc
Idling speed 2700 rpm
Spark plug Champion RCJ7Y, NGK BPMR7A
Electrode gap 0.02 "
Air filter type Felt
Lubricants Oil tank volume 0.84 US pint
Oil pump capacity 0-0.021 ml/min
Cutting equipment Chain pitch 3/8"
Recommended bar length, min-max 15"-28"
Chain speed at max power 67.9 fts
Overall dimensions Weight (excl. cutting equipment) 14.1 lbs
Husqvarna 372XP Chainsaw W/18in Bar & Chain
Your Cost: $865.00
Husqvarna 372XP Chainsaw W/20in Bar & Chain
Your Cost: $875.00
Husqvarna 372XP Chainsaw W/24in Bar & Chain
Your Cost: $885.00
Husqvarna 372XP Chainsaw W/28in Bar & Chain
Your Cost: $885.00
/ Which Chainsaw ? #43
That's some good prices on the 365. His dealer don't seem out of line on the 372 though
/ Which Chainsaw ? #44
The last time I was at Eble's here in mid Michigan about 3 weeks ago and they had 1/2 a pallet load left. They were under $600, real tempting. If they were made with the heated handles I would have bought one. 231 826 3334 talk to Paul. Great people to deal with and they know saws. If I have had any problems they fixed it while I waited. If not buy one from XYZ, does not sound like your dealer knows much about saws. CJ
/ Which Chainsaw ?
Thanks to everyone for their opinions & offers. The dealer that I talked to yesterday called me back just a few min. ago. He has now offered me the 372xp with 24'' bar for $760.00 OTD.I told him I would be on the way to pick it up .
Again,
thanks to all
/ Which Chainsaw ? #46
Again,
thanks to all
That is a screamin deal. Haven't seen one that low in years!
/ Which Chainsaw ? #47
Split the difference ...... 562XP. Put a 20"tech Lite bar on it and enjoy a fairly light saw with close to 70cc power .
/ Which Chainsaw ? #48
That's what I did. Heck of a rig with that bar!!!
/ Which Chainsaw ?
Just got home and fired it up. With the comp. button pushed in . It's not as hard to pull than my 53cc saw. Can't wait to try it out.Sold me the saw for $690.00 + tax for a total of $760.00. She sounds like she'll really cut !
/ Which Chainsaw ? #50
Just a heads up about using de-comp on the new 372Xp XT saws.
Per a dealer on my site on hard starting 372 XT's
Cold start: Do NOT use the deco. Not sure why, but I suspect this top mount deco drops the compression a little too much in addition to makeing that first "pop" harder to hear. Especially when the saw is new. People would come in with flooded saws that would really fog up the parking lot when we got them going. Part of the problem though was guys continuing to pull with the choke on waiting for that pop. One is a good friend of mine and fellow member on these sites. I watched him trying to start his 2172 and counted 20 pulls with the choke on before I yelled at him to stop. Every person that has had this issue has solved it simply by not using the deco.
Warm start: Carb is just not adjusted right, because this is not a problem I've seen with any of the saws we've sold. I suspect that it's a little too lean on the LO side. Every one of these things come out of the box too lean on both the Lo and HI. When setting up a saw I open them both at least 1/4 turn before even trying to start it, then adjust from there.
/ Which Chainsaw ?
The dealer (B- I got there) Said that he had his men put fuel in start and service the saw. Whatever that means. I started it when I got home (I assume it was cold).I pulled the choke out and pushed in the decomp. button and pulled .It tried to start (pop?) Decomp button is now out. I pushed in the choke,pulled again and it started right up.I'm ready to try it out,but it's dark now
/ Which Chainsaw ? #52
Nice deal. I think you will like the 372 alot
/ Which Chainsaw ? #53
When you get used to the saw you will be able to tell how many pulls hot or cold they take to start. Each one of mine I can tell when it will pop [try to start] and hit the choke quick enough so they will stay running when they are cold! I think every saw I have gotten lately is on the lean side, some so much so you have to pull the limiters to get them right. The EPA as always is screwing up even chainsaws. XYZ how have the 562's been doing for you? CJ
/ Which Chainsaw ? #54
The Stihl MS361 had that identical problem. Easiest to flood saw I ever ran. I start it without the decomp and that first 'pop' is really only a "burble". Hard to notice unless one is used to it.
Harry K
/ Which Chainsaw ? #55
Just a side thought Ken, please wear all your safety gear with the 372. It is the one saw that I have had the most kickbackes with hands down [I admit it is in my hands more than my other ones] But with that being said the power to weight and the RPM's the saw will turn they kick back HARD and FAST. Anyway be Carefull!!! You'll love the saw. CJ
/ Which Chainsaw ? #56
I dont have a need for that saw class or own a 562. I like weight of 550 545 346 saws, then I try to skip up to higher 70pluscc saws for the next class.
I do know loggers using the 562 daily in work production and love them.
/ Which Chainsaw ?
thanks for the heads up about the saw kicking. I'm 55 and have used saws all my life,but, never 1 this big.It's good to hear from someone that know how big saws can / will react . When a body part comes in contact with a saw blade , It usally doesn't turn out very well
/ Which Chainsaw ? #58
Thanks, same reports I have been getting. Looks like a 562XPG will soon be home. CJ
/ Which Chainsaw ? #59
I have sold my last 3 272/372's to friends and they all got the lecture on kickback. So far they have only got 1 person. My bigger saws seem to kick straight back [like with a top pinch] but I don't know if it is the balance of the saw or handle location on the 372 but with a 20" bar they tend to kick up. But even with that they are still my faviorite saw. Maybe the 562 will change that being I am getting older! CJ
/ Which Chainsaw ?
Got to use the saw today on about a 35-40'' tree that fell several months back. I can say that, this saw loves to eat trees.Went through this tree like a butter knife through hot butter ! This things really throws out the shavings.I've never had anything eat through a tree like this.I'm amazed to say the least ! I was concerned about the weight of the saw and, thought I would give out/tired after using it.LD1 was right when he said, The saw would be in my hands less time vs using a lighter less powerfull saw.
This is an ALESOME SAW!!
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
FORD 5610 TRACTOR (A64276)
FORD 5610 TRACTOR...
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
(1) 16"X26'7"LO-1 1/2" THICK CULVERTER PIPE (A64281)
(1) 16"X26'7"LO-1...
1985 GLASSTREAM 176 ANGLER 17.5' BASS BOAT (A64276)
1985 GLASSTREAM...
