Which Chains are best for R4 tires?
   / Which Chains are best for R4 tires? #21
Have you noticed a rough ride on gravel or chert surfaces ?
Wow I'm surprised I have a little BX2230 with the rear mounted 60" snow-blower and never ever needed chains or got in to situation that this tractor got stuck and I pull kids on theirs sleds every x-mass around on th quite deep snow
Paul.W
Caledon
Well, I tried installing the ladder chains from WALCO and there just wasn't enough clearance on my BX25. Next, I will check out the cost of wheel spacers. (Probably not cheap.)
   / Which Chains are best for R4 tires? #23
Paul.W
Caledon
What depth is the "around on th quite deep snow" ??
   / Which Chains are best for R4 tires? #24
No but then again, I do not go fast on these surfaces. Also my tire pressures are not high which I am sure absorbs some of the shock.is The other thing is with ags is that the chain itself does not go much beyond the lugs and when the chain rides between lugs, the lug is taking up alot of the pounding. In all instances in gravel I can see the chain marks in the gravel so I know they are aiding in tractive situations. When there is ice under snow, my bare ags spin. The tractor just keeps pushing with chains in the same situation.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2018 Honda TRX250TM ATV (A56859)
2018 Honda...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2020 HINO 268 26FT NON CDL BOX TRUCK (A59575)
2020 HINO 268 26FT...
