Which Bush Hog for BX22??
   / Which Bush Hog for BX22?? #1
GaryG
San Diego
BX22
I made the plunge and ordered a BX22 with tiller and Box Scraper. I need a brush hog. What are you all using on the BX22? Thanks again for your wealth of knowledge.
   / Which Bush Hog for BX22?? #2
Don't go over 4 ft. A 42" might be better, depending on what you are cutting. The hardest thing to handle is thick, tall grass. I have a 4ft med duty Fred Cain Agricutter hog. Last year I cut about 3 acres of 3-4 ft tall bahia grass and it was slow going. Looking back I was trying to cut too low. I should have made a cut with the hog set higher, then come back. I cut it at about 5 inch setting and just plainly didn't enjoy it! Everthing else I have cut with it has been great and a good match for the size and power of the BX.
Terry
   / Which Bush Hog for BX22?? #3
I have a 48" HOWSE bushhog. The BX22 handles it fine but it attatches A LOT easier if you move the 3pt hitch pins on the bushhog towards the inside. I have no problem knocking down 2" saplings and blazing some trails in the woods with mine. The only problem I had was that the bolts that attatch the gearbox became loose. I think it was my fault for not tightening them down often enough. If you check my pictures I think there is a picture of my BX22 with the hog on it. Chris
   / Which Bush Hog for BX22?? #4
A friend of mine has a BX2200 and a Woods BB48. The Brush Bull is a heavy mower, really too heavy for the BX. Getting the blades moving just about kills the tractor's engine, but once up to rpm it does great. I mowed weeds with it last year that were taller than the ROPS and the tractor didn't bog at all. As for transporting, a lighter mower would be better suited for the BX.
   / Which Bush Hog for BX22?? #5
</font><font color="blue" class="small">( I have a 48" HOWSE bushhog. The BX22 handles it fine but it attatches A LOT easier if you move the 3pt hitch pins on the bushhog towards the inside. )</font>
I got the 42" HOWSE bushhog, but haven't used it yet with my BX2200. Dealer delivered the machine with the FEL. MMM, and hog attached. I wanted to just mow, so I took the FEL and Hog off.....it was a royal pain getting the hog off......I'll have to take a gander at the pins on it and perhaps move them inside myself. I plan on using it this weekend (weather permitting) and that might just be the ticket.
Thanks,
   / Which Bush Hog for BX22?? #6
I have a LandPride RCR1548 (48") and have used it without difficulty.
Seth
   / Which Bush Hog for BX22?? #7
I have on order a King Kutter 48" XB model, supposedly made for the subcompacts. Hope for easy hookup and satisfactory performance.
   / Which Bush Hog for BX22?? #8
If you are going to be cutting thick and tall stuff. I would go with the 42" Unit. If you are not going to be cutting that tall of stuff or not very thick stuff I would go with a 48". It basically comes down to what you are cutting with it.
Knowles
   / Which Bush Hog for BX22?? #9
I’d go no bigger than a 42” rotary cutter… you only have ~~ 17 PTO hp with an under 60 cid engine with virtually no torque screaming @ 3000 rpm… so you have these limitations you are bounded with…
You may take out a 1” sapling occasionally now and then, but I wouldn’t make it any habit… the Kubota will cry for mercy… so be nice to her and treat her to a 42” cutter and stick with nice grassy and very light woody materials to cut… /forums/images/graemlins/smile.gif
   / Which Bush Hog for BX22?? #10
I also have the KK 4' XB series cutter on order. Does anyone have any experience with this cutter?
I plan on using it on my BX1800 to clear a little under an acre of underbrush (brambles, saplings, etc.). Like GFB says, it's supposed to be made specifically for the subcompacts; at least that's what King Kutter told me when I called. Any advice on this model would be greatly appreciated! Thanks in advance!
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52748)
Texas Post Driver...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2015 Jeep Compass AWD SUV (A50324)
2015 Jeep Compass...
377670 (A51573)
377670 (A51573)
