Which Box Blade for a 3320
   / Which Box Blade for a 3320 #1
cartod
Platinum Member
Northern, West Virginia
JD 4066, 1023
I need a box blade for my new 3320, which brand should I get, and should I get a 5' or 6'. I have ag tires.
   / Which Box Blade for a 3320 #2
I brought 6' Frontier through my JD dealer and it has been a good buy. I am going to attach a Ratchet Rake to see what it will do. But it needs nothing added as it is sturdy and fairly low priced.
Jim
Jim
How much $ is a 6' frontier?
   / Which Box Blade for a 3320 #4
I have a 4310, which is similar hp. I use a 6 ft King Kutter with a hydraulic top link. I could not think of a better combination.
Do you use an Imatch? Does the king kutter match up with Imatch?
   / Which Box Blade for a 3320 #6
Agree, the iMatch with the hyd. top arm is for sure the way to go for a great combo.
If the BB doesn't match, then alter it so it does. Will make you happy.
The Deere dealer can give you his Frontier BB price. It may vary.
   / Which Box Blade for a 3320 #7
I agree that a six foot BB would be a nice fit for a 3320 for normal use. I have a five footer.....and dont use it too much as a box blade. Instead I hang lots of suitcase weights on mine and use it for ballast. I think it weighs about 900 lbs. Really can dig too. I like how compact it is....when I'm working in the woods.....which is most of the time.
I only have $200. in mine (plus the suitcase weights). I'm not sure which size I'd buy if buying again. I do like that it does not extend beyond my tire width.
   / Which Box Blade for a 3320 #8
I would opt for the 6' unit to cover your tracks. The 3320 is heavy enough to pull a 6' box blade, but i will warn you that if the rear tires aren't filled you will defiantly notice a loss in traction with the teeth down. :2cents:
   / Which Box Blade for a 3320 #9
The prices do vary. Our dealer sold it for a few Hundred dollars so I was surprised how low. I also got an Imatch which has been a Godsend foruse with the box blade, scraper and MX5.
You might also consider the Ratchet Rake as it has been unbelievable.
Best to you,
Jim
   / Which Box Blade for a 3320 #10
I've got the Frontier BB2065 (5 1/2') box blade on my 3320 and its been perfect for that size tractor. With the I-match and top & tilt it goes on or off in seconds. Cost was $800 new a few years ago.
16FT Flatbed Trailer (A51573)
16FT Flatbed...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
2011 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2011 INTERNATIONAL...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
