Which Box Blade for a 3320
   / Which Box Blade for a 3320 #1
cartod
Platinum Member
Northern, West Virginia
JD 4066, 1023
I need a box blade for my new 3320, which brand should I get, and should I get a 5' or 6'. I have ag tires.
   / Which Box Blade for a 3320 #2
I brought 6' Frontier through my JD dealer and it has been a good buy. I am going to attach a Ratchet Rake to see what it will do. But it needs nothing added as it is sturdy and fairly low priced.
Jim
Jim
How much $ is a 6' frontier?
   / Which Box Blade for a 3320 #4
I have a 4310, which is similar hp. I use a 6 ft King Kutter with a hydraulic top link. I could not think of a better combination.
Do you use an Imatch? Does the king kutter match up with Imatch?
   / Which Box Blade for a 3320 #6
Agree, the iMatch with the hyd. top arm is for sure the way to go for a great combo.
If the BB doesn't match, then alter it so it does. Will make you happy.
The Deere dealer can give you his Frontier BB price. It may vary.
   / Which Box Blade for a 3320 #7
I agree that a six foot BB would be a nice fit for a 3320 for normal use. I have a five footer.....and dont use it too much as a box blade. Instead I hang lots of suitcase weights on mine and use it for ballast. I think it weighs about 900 lbs. Really can dig too. I like how compact it is....when I'm working in the woods.....which is most of the time.
I only have $200. in mine (plus the suitcase weights). I'm not sure which size I'd buy if buying again. I do like that it does not extend beyond my tire width.
   / Which Box Blade for a 3320 #8
I would opt for the 6' unit to cover your tracks. The 3320 is heavy enough to pull a 6' box blade, but i will warn you that if the rear tires aren't filled you will defiantly notice a loss in traction with the teeth down. :2cents:
   / Which Box Blade for a 3320 #9
The prices do vary. Our dealer sold it for a few Hundred dollars so I was surprised how low. I also got an Imatch which has been a Godsend foruse with the box blade, scraper and MX5.
You might also consider the Ratchet Rake as it has been unbelievable.
Best to you,
Jim
   / Which Box Blade for a 3320 #10
I've got the Frontier BB2065 (5 1/2') box blade on my 3320 and its been perfect for that size tractor. With the I-match and top & tilt it goes on or off in seconds. Cost was $800 new a few years ago.
New Idea 6254 Round Baler (A50774)
New Idea 6254...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
Wright Sentar (A50120)
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
2009 John Deere TX 4X2 Gator (A50121)
2009 John Deere TX...
2011 Chevrolet Silverado (A50120)
2011 Chevrolet...
