Which Back hoe?
/ Which Back hoe? #1
crowlej
Valley Cottage, NY
John Deere 2320
I'm buying a JD 4300 with 430 loader and a back hoe... my question is which hoe the 47 or 48? the 48 offers 1' more digging depth (8'6" vs. 7'6") at a premium of about $1,000! Is it worth it? is it more HD than the 47 or only 1' longer?
/ Which Back hoe? #2
crowlej,
If money isn't that much of an issue or should I say if you can come up with it I woudl invest in the 48 for sure. If you look at them side by side you will want the 48. That extra foot will make you happier when you need it and you will and more. /w3tcompact/icons/smile.gif.
Darin
/ Which Back hoe? #3
Bigger is always better. I've learned over the years to always go with more than what I think I need. Always regret not going up in size. Better to spend the extra $1k now than to regret it later. If you look at them side by side the 48 is definitely more hoe than the 47.
/ Which Back hoe? #4
I have the JD48 hoe on my 4300. I think that in addition to the extra foot of digging depth you get about a foot and a half more reach. I frequently use every inch of reach with my 48 so I could not imagine living with any less. If you can swing the bucks I would certainly go with the 48.
I love the smell of diesel in the morning. /w3tcompact/icons/smile.gif
/ Which Back hoe? #5
Crowlej,
Check the specs on how much each of the hows can lift, the digging force, etc. Reach can be important if you are digging a deep hole but its also very important if you are trying to dig out a large stump. I think there are more important differences between the 47 and 48 besides the digging depth.
I'm assuming that you can put a 48 on a 4300.
Later....
Dan McCarty
/ Which Back hoe?
Yes JD lists it as an option on the 4300 so assume the tractor and the hydraulics are up to the challenge.
Thanks for the reply
/ Which Back hoe?
How does the 48 work overall on the 4300? I thought maybe it would be too much for the size of the Tractor!?
/ Which Back hoe? #8
The backhoe works very well on a 4300. It seems to be just the right size to me. I have seen a few of the larger frame (4500-4700) tractors with the 48 attached and the hoe actually looks a little small on these machines, in my opinion. I have the 18” bucket on mine, which seems to be a good compromise size as far as volume versus digging force. I run the tractor at about 1500 RPMs and the hoe seems to have plenty of power. I now have about 75 hours on my 4300 and I would estimate that at least half of that is using the hoe. I have alot of very soft ground on my land due to poor drainage and waterproof clay, so I often run the tractor with just the backhoe attached without the loader. The front end is a little light without the loader but I find that the unit has much better floatation and maneuverability this way. Hope this helps.
/ Which Back hoe? #9
<font color=blue>...so I often run the tractor with just the backhoe attached without the loader. The front end is a little light ...</font color=blue>
Michael,
Before you hurt yourself... very very unsafe... that backhoe upsets the center of gravity and balance drastically without that loader attached... /w3tcompact/icons/crazy.gif
If you pull the loader off... also pull the backhoe off.
/ Which Back hoe? #10
I would agree that the 48 hoe on the 4500 -4700 is a bit on the small side -wish that they would make a bigger unit!!!
/ Which Back hoe? #11
I am aware of the risks. I am certainly not recommending anyone else operate his or her tractor like this. I move the tractor verrrrrrry slowly and carefully (always on flat or nearly flat ground) and I personally take full responsibility for my actions.
/ Which Back hoe? #13
I am curious as to the price of a JD 47 or 48 backhoe. I have rough estimates for kubota and other aftermarket backhoes but I haven't heard anyone other than cowboydoc mention costs. (Cowboydoc got too good of a deal) Are the JD hoes pto pump driven or do they run off the tractor hydraulics or can they be used either way?
/ Which Back hoe? #14
They are driven off the tractor hydraulics. Two quick-couple hoses. That part is clear.
As to price. Duh. I am looking at two written proposals from the same dealer, one for a 48 hoe on a 4400 and one for the same hoe on a 4600. Supposedly, the proposal lists the list prices, after which he deducts 11% discount from the total. This was his first offer out of the box. The weird thing is the list price for the hoe in the 4600 proposal is $7734 and on the 4400 proposal it is $7190.
In proposals from 2 other JD dealers on 4400, the list price of the 48 hoe is given as $7578 and $7194, but both of these dealers separately price out the power beyond, which is required for the hoe, at $190. One of the dealers then took 10% off in the proposal; the other took 3% off, but only after I asked for a discount.
Welcome to the wonderful world of JD pricing. Remember Crazy Eddy? Remember chaos theory? Remember P.T. Barnum?
/ Which Back hoe? #15
The best price that I had gotten was $6600 with the power beyond kit installed and setup on the 48. That was before the deal on this other one came through.
<P ID="edit"><FONT SIZE=-1>Edited by cowboydoc on 07/14/01 08:29 AM (server time).</FONT></P>
/ Which Back hoe? #16
I ended up paying $ 128 for the power-beyond kit and $ 5950 for the 48 hoe with 18 " bucket. I was quoted 3 different prices for the hoe ranging from $ 5950 to $ 7000.
List price is $ 7519.00 w/ 12" bucket.
Does anyone know if the 49 hoe will fit on a 4700??
/ Which Back hoe? #17
I paid $5900 for my 48 hoe with an 18" bucket when I bought my 4300. It probably would have been a little more expensive if I had purchased it separately.
/ Which Back hoe? #18
Just so everyone doesn't get the impression that I am constantly pulling wheelies with my 4300 when I run the backhoe without the loader attached I conducted a little experiment. I parked the tractor in my flat, level, and hard driveway with just the backhoe attached, and lowered the stabilizers to the ground. I then fully extended the hoe straight behind the tractor with the bucket about 6" off the ground. I then raised the stabilizers slightly so that the pads were about 2" off the ground. No wheelies yet. I then got off the tractor and placed most of my 170 lbs on top of the backhoe bucket. It took nearly all my weight to begin to lift the front wheels. I would estimate at least 150 lbs. Doing some quick math I calculated that the front wheels must still have at least 370 lbs of weight on them with the hoe fully extended and the stabilizers up. With the hoe in the normal transport position the number would be substantially higher, I would estimate at least 500 lbs. The front end is noticeably lighter when driving the tractor like this, but I don't feel that it is unsafe if operated with caution on flat ground. Your mileage may vary./w3tcompact/icons/smile.gif
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
16in. Bucket with Teeth Excavator Attachment (A64194)
16in. Bucket with...
2025 LandHonor LHR-SBC19 19 Gallon Portable Sand Blasting Cabinet (A64194)
2025 LandHonor...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
