Where to trailer tie down your 4300 rearend?
   / Where to trailer tie down your 4300 rearend? #1
Anonymous Poster
Epic Contributor
Where does everyone hook to/or chain to there rear of the 4xxx tractor for trailering.
I use to binders in the front, hook to the frame/bumper.
Before on the rear, I used to binders and hooked the chains to the 3pt arms, where the lift links are. The dealer actually shipped it this way also.
Also I usually have a brush hog attached....
I don't see any other 'safe' place to chain to?
I wish JD would place some hooks on the rear to trailer it.
Thanks,
John
Put a clevis on the piece below the lift arms where trailer/ball hitch can be installed...I cannot think what the proper term for this is,other than it is where I have the clevis installed on mine,I just run the chain through it( the clevis ).
   / Where to trailer tie down your 4300 rearend? #3
I use racheting nylon straps and in the rear run it up and in front of the ROPS, behind the seat and over the fenders. I think that a high attachment point helps keep the tractor down and it doesn't bounce at all.
I don't recall anyone else ever mention using the ROPS as a tiedown. It should be plenty strong.
   / Where to trailer tie down your 4300 rearend? #4
I put a 5000lbs 2" ball on the hitch and shortened the hitch for more strength and it is even out of the way for the back hoe. I wrap a chain around it, boom your done. in the front I run the chain around the front weight bracket (frame).
   / Where to trailer tie down your 4300 rearend? #5
<font color="green"> I use racheting nylon straps and in the rear run it up and in front of the ROPS, behind the seat and <font color="red"> over the fenders</font> . I think that a high attachment point helps keep the tractor down and it doesn't bounce at all. </font>
Won't that break the fenders or atleast deform them?
W/o an attachment on I chain thru a clevice or ball on drawbar .
W/ an attachment on I chain over the 3 PT arms at the pins
and pull against the top link tower.
This holds the attachment down also.
   / Where to trailer tie down your 4300 rearend? #6
"Drawbar" was the word Steel Wheels was looking for. I use the same method myself except when the backhoe is on. In that case I just pin the clevis through the hole where the drawbar attaches to the rear end.
   / Where to trailer tie down your 4300 rearend? #7
I like havis a clevis on the drawbar with a chain going all the way through it. Minnesota has this code that you are actually suppose to have 4 different complete ties. Meaning you can't run the chain through the clevis but two chains just to the clevis. If is kind of a dumb code and I am not sure how many police would catch it. I did get it on our Bobcat back hoe though. The chain went through the clevis and we got a warning for it.
Murph
   / Where to trailer tie down your 4300 rearend? #8
I took some of my steel hauler chains 3/8 x 20' hi test
and cut in half then put grab hooks on the cut end.
Works good for small stuff and my big hoe plus lite to
carry.
   / Where to trailer tie down your 4300 rearend? #9
I have had the pin in the clevis come out and also the clevis bend forcing the pin out (all had a spring wire clip holding the clevis pin in) ... so what I do now goes back to the orginal method I've used of the 2" trailer ball in the draw bar and pass the chain around it ... I still like the clevis and continue to watch for a different pinning method... maybe just use a bolt and nut as a pin ...
   / Where to trailer tie down your 4300 rearend? #10
I have never had that problem, but your right, it could happen. I do have the availability to tie into the brackets that hold the drawbar in place or where it allows the drawbar to move from side to side. I just need to get another couple of chains. Like I said before, Minnesota the clevis idea is not acceptable. If pulled over again by one of them Highway vehicle inspections I think I would get a ticket.
Murph
2012 Chevrolet Captiva Sport SUV (A50324)
2012 Chevrolet...
(5) Misc Tires (A50121)
(5) Misc Tires...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
