Where to put winch?
/ Where to put winch? #1
BAGTIC
Thayer, MO
Where do most people put a winch on the PT425?
I would like one mounted on the front so I could use the bucket or forks as a 'spade' to get a little more pull. The PT425 is so light that in many cases it would slide before what I was trying to move.
/ Where to put winch? #3
You could build a bracket and bolt on front or top of forks. To pull something big. I would jam the forks into the ground, and winch. Another way is to chain/strap the PT rear end to a tree and pull with the winch.
/ Where to put winch? #4
/ Where to put winch? #5
I'm thinking of using one mounted to a hitch receiver plate like this:
Or, this:
Then, I could move it to either front or back (assuming I have receivers) or use it on my truck...
/ Where to put winch? #6
Or, this:
/ Where to put winch? #7
I like the idea of jamming the forks into the ground for an anchor. /forums/images/graemlins/smile.gif
/ Where to put winch? #8
/ Where to put winch? #9
</font><font color="blue" class="small">( You could build a bracket and bolt on front or top of forks. To pull something big. I would jam the forks into the ground, and winch. Another way is to chain/strap the PT rear end to a tree and pull with the winch. )</font>
The forks sound like a good idea for planned projects but many times when you could use a winch your not going to have the forks with you. You could chain the rear of the tractor, just make sure the chain and winch are not stronger than the tractor. I would hate to be a mile out in the woods with 2 halves of a PT,lol.
What I carry in the tool box of my landscape trailer, is a 12 volt winch mounted to a portable plate with adjustable chains so I can attach it to whatever is handy. Also have a small car battery in case I am not near a veicle. I used it just last week to get my Walker mower out of the mud.If you could find a place on the tractor to carry a setup like that, than you could winch heavy stuff without using the PT as your anchor. For lighter stuff and for getting the pt unstuck, you could still chain the winch to the tractor. Make up some longer wires and you would not have to carry the extra battery.
/ Where to put winch? #10
/ Where to put winch? #11
An electric winch is also on my list. For an out in the woods option you can carry on foot, no need to lug a battery this would make a nice alternate solution.
( Winch )
/ Where to put winch? #12
( Winch )
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2 Horse Trailer (A62613)
2 Horse Trailer...
1043 (A60430)
1043 (A60430)
2015 Ford C-Max Hatchback (A61574)
2015 Ford C-Max...
2018 LANDOLL 330 S/A  DROP DECK TRAILER (A59912)
2018 LANDOLL 330...
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
