Where to mount tilt-meter
   / Where to mount tilt-meter #1
madpogue
Madison, WI
John Deere 790
Rig: '07 790 MFwd, R1 tires, about 20 hrs.
I got the Tilt Meter featured here on TBN. To be honest, I'm not too impressed with the construction. Bracketry could be WAY simpler, with fewer fasteners that could work loose. Poorly packed; I had to fish fasteners out of the box, and a nut was trapped inside the bracket.
Anyway, I'm wondering if anyone's mounted one of these on a 790, and where would be the best place. If possible, can you post a pic? I'm 2.5 hrs away from the tractor right now, and won't be out there again 'til next weekend, so I'll need some visual help.
Ideas?
   / Where to mount tilt-meter #2
This is where and how I mounted mine (attached pics). The pics just give a few different views.
Make sure you're on a fairly flat, level surface when you mount the tiltmeter.
I drilled my hood (it was a used tractor anyway), but the double sided tape is quite robust if you don't want to drill.
This was on a Deere 670 which was the 790's older brother.
Now, I'm sure you're going to ask why I didn't mount it on my 790. Well, the 670 was the first tractor I had operated since my Dad passed away, so I wasn't real used to them. Also, I'm much more aware of my property so I don't feel the need for the tiltmeter as much as I did. And, with a lot more hours, I'm more familar with the machine's capabilities and limitations (not that I'm getting complacent).
   / Where to mount tilt-meter #3
Ideas?
As long as these have been sold here and even when members were purchasing them before, I think this is the first complaint that has ever been aired about them. When they were first marketed, they just had simple L brackets. The L brackets didn't allow mounting on the many angles that some tractors had. That is when Rick added a different bracket to the package. The new brackets seem to have worked much better that the old ones. Personally I don't use anything provided to mount either of my tilt meters. One of the meters is mounted to my overhead console and the other is mounted to the canopy above the slide rail. Here is a picture of the console mounted meter. I don't have a good picture of the side meter.
http://www.tractorbynet.com/photos/showphoto.php/photo/2117/sort/1/cat/500/page/1
Good point, Jerry, that the current mounting system allows for side-to-side leveling. But looking at Roy's setup, even though it's "fixed" side-to-side, it looks much more stable than the current bracket with the single block in the middle. I'll have to see how my wife feels about me drilling thru the hood. I'd feel more confident about the double-sticky if it were on the ends like Roy's. Hm, I also wonder how well that stickum would hold up to the occasional diesel spill.
Roy, thanks for the photos. I have a "from the seat" photo of our 790, and was trying to imagine how the meter would fit in front of or behind the fuel cap. Hard to get that perspective/scale with just a photo in one hand and the meter in the other. Your photo of the meter installed demonstrates how visible it is, even mounted on the far side of the cap. I'm gonna give that location a try. I was hoping to find a way to mount it to the top edge of the instrument panel bezel, but I'm sure it would be visually blocked by the steering wheel.
BTW, why is yours off-center a bit? Seems like, with the slight "crown" of the hood, it'd be most level dead center.
As for the fasteners, Rick went to the trouble of putting nylock nuts on the fasteners that hold the main meter body to the rear plate part of the bracket (thumbs up). But the fasteners at the pivot point are just plain-old zinc screws with square-head nuts meant to be kept captive in the bracket (it was one of those nuts that got trapped inside the bracket cavity, 'cuz the bolt had vibrated off it in shipping). P'raps a coupla bolts going all the way thru, with nylock nuts, will do 'er. Or maybe just some loctite. In my short experience using this kind of equipment, I've found that vibration isn't just an annoyance, it can (pun intended) be your undoing.
   / Where to mount tilt-meter #5
Actually, I eyeballed it in place. Once I realized I'd drilled the first hole off center..well, being perfectly centered wasn't too important. The camber of the hood makes it look more offset then it actually was.
The main thing is that it be level to the ground.
Dang, I was hoping for a high-falutin' answer about ergonomics and feng shui, like how all the fab new cars have the dashboard off to the driver's right, etc. etc. :)
Yeah, it provides, eh, visual balance with the exhaust stack, yeah, that's the ticket!....
   / Where to mount tilt-meter #7
:D
I don't get it.......;)
   / Where to mount tilt-meter #8
The layout and positioning of the tiltmeter was carefully calculated using the latest statistical software along with a portable laser theodolite using GPS/satellite positioning methodologies.
That, along with a highly paid ergonomics consultant to establish optimal positioning relative to the primary operator's dominant eye and neck angles for reduced strain and fatigue, resulted in the most statistically significant position of the calibrated instrumentation (i.e. Tiltmeter).
That's how I actually did it...but I didn't want to you men to think I was being overly technical.
   / Where to mount tilt-meter #9
Roy, Would it be to much to ask what an installation like that would cost?:D
O'well never mind. I don't think I could afford it anyway.
   / Where to mount tilt-meter #10
That's right...you couldn't. I had to make my wife get a job to pay for it.
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
Utility Trailer (A52377)
Utility Trailer...
Lastec 721XR-US Mower (A53314)
Lastec 721XR-US...
2007 Honda CR-V SUV (A55758)
2007 Honda CR-V...
Hydraulic Concrete Mixer Skid Steer Attachment (A55787)
Hydraulic Concrete...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
