where to mount tilt meter on L3010
   / where to mount tilt meter on L3010 #1
Moon
Platinum Member
SE Ohio, Meigs County
Kubota L3010HST R4's, Scag Wildcat ZTR, 61
Hey Guys,
I've had my tilt meter longer than I care to admit, but have not mounted it on the tractor. I am looking for just the right spot but can't come up with one. Any examples of where you mounted your tilt meters on a L3010 or similar bota?
Thanks,
Moon of Ohio
   / where to mount tilt meter on L3010 #2
Moon I don't own a Kubota but I noticed in your bio that you had a FEL on yours. Check the link to pictures of my TC-40D and see if the FEL support mount will work for you like I mounted mine. It's easy to see and protected from damage where it's located. And you don't have to drill any holes if you use silicone adhesive. /forums/images/graemlins/wink.gif
Thanks Pineridge.
It looks good there. Does it work as well from there as it would up on the hood? The one I got also has the side attached forward tilt, I wonder if it could be mounted seperate in some other obscure location?
Thanks again,
Moon of Ohio
   / where to mount tilt meter on L3010 #4
</font><font color="blue" class="small">( I wonder if it could be mounted seperate in some other obscure location? )</font>
I mounted mine front and center where I can see it easily - right above the instrument pod.
Mark
   / where to mount tilt meter on L3010 #5
just make sure u mount it in a spot that is easy to see.
   / where to mount tilt meter on L3010 #6
Moon it is easy to see and far less likely to be bumped or knocked around than on your hood. If you will be mainly using this for your property then you will quickly memorize your lot grades as indicated on the slope meter. From that point forward you will be glancing at the meter only occasionally as a reference point.
   / where to mount tilt meter on L3010 #7
I agree with Mike, and have mine mounted there on my L3010. Had it on the hood for a while but it not only got in the way, but was extremely distracting! Found myself watching the little ball instead of looking for rocks and dips in front of me! Pete
Thanks guys!
Mark, did you have to drill to mount yours?
Boondox,
Did you mount both side and forward/back tilt meters on the column like Pineridge? If its not too much trouble I'd like to see a pic.
Thanks again,
Moon of Ohio
2011 PROCO 130BBL VACUUM TRAILER (A53843)
2011 PROCO 130BBL...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
23222 (A50323)
23222 (A50323)
2011 GALYEAN 130BBL VACUUM TRAILER (A53843)
2011 GALYEAN...
2015 MACK CHU (PINNACLE) TRI AXLE(INOPERABLE) (A53843)
2015 MACK CHU...
