Where to find info on building a pier/boat dock
   / Where to find info on building a pier/boat dock #11
This is one of them driving in a short post for the pier.
   / Where to find info on building a pier/boat dock #12
This shows the short pier posts and one long dock post installed.
   / Where to find info on building a pier/boat dock #13
Here is a picture of the trackhoe and the crew working on the boat lift roof frame.
   / Where to find info on building a pier/boat dock #14
This is the almost finished product.
Terry
   / Where to find info on building a pier/boat dock #15
Side view of the finished product.
Terry
   / Where to find info on building a pier/boat dock #16
Here we use air hammers even smaller electric hilti hammers to drive 6 inch steep pipe possts in for floaters. My friend William even made one that has spud poles the walkway pivots hold it inplace against the current. William had a work barge with a tower on it, the tower had a sliding 500pound weight attached to a car axle type drop hammer winch. then later and old dozer winch. the poles were plubmed them hammered in. If its a TVA site you may want to check with the authorities to see what the deck square footage is there . Here I think you can have 3 decks that have 400 sf each.
   / Where to find info on building a pier/boat dock #17
Terry,
Great Pics. Love the trackhoe on the barge!!!!!!!
Eddie
   / Where to find info on building a pier/boat dock #18
Re stability;
The larger the more stable the floating dock will be.
I have a 10 x 10 with 6" of foam and it will handle comfortably 6 folks (not all at same corner).
I once counted 22 people on the 12 X 16 dock and nobody had wet feet!
The flat bottom foam makes for a very stable platform due to the wide footprint.
Barrels would kinda be like a ladies high heel shoe, ie sink 'till you get to the wide part.
   / Where to find info on building a pier/boat dock #19
Blue 55gal plastic drums using stainless steels strapping work very well as pontoons each drum should safely carry 225 pound @ 50% flotation.
same principle as below
   / Where to find info on building a pier/boat dock #20
Around here piers or pylons are driven in with excavators with cup arrangement on a rock breaker, this vibrates them in very easily with no damage that you get when hammered in.
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
2017 Ford F-550 4x4 Crew Cab Stellar 7628 7,500lb. 3.75 Ton Crane Service Truck (A55973)
2017 Ford F-550...
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
2016 Chevrolet Tahoe SUV (A55973)
2016 Chevrolet...
