Where to find info on building a pier/boat dock
   / Where to find info on building a pier/boat dock #11
This is one of them driving in a short post for the pier.
   / Where to find info on building a pier/boat dock #12
This shows the short pier posts and one long dock post installed.
   / Where to find info on building a pier/boat dock #13
Here is a picture of the trackhoe and the crew working on the boat lift roof frame.
   / Where to find info on building a pier/boat dock #14
This is the almost finished product.
Terry
   / Where to find info on building a pier/boat dock #15
Side view of the finished product.
Terry
   / Where to find info on building a pier/boat dock #16
Here we use air hammers even smaller electric hilti hammers to drive 6 inch steep pipe possts in for floaters. My friend William even made one that has spud poles the walkway pivots hold it inplace against the current. William had a work barge with a tower on it, the tower had a sliding 500pound weight attached to a car axle type drop hammer winch. then later and old dozer winch. the poles were plubmed them hammered in. If its a TVA site you may want to check with the authorities to see what the deck square footage is there . Here I think you can have 3 decks that have 400 sf each.
   / Where to find info on building a pier/boat dock #17
Terry,
Great Pics. Love the trackhoe on the barge!!!!!!!
Eddie
   / Where to find info on building a pier/boat dock #18
Re stability;
The larger the more stable the floating dock will be.
I have a 10 x 10 with 6" of foam and it will handle comfortably 6 folks (not all at same corner).
I once counted 22 people on the 12 X 16 dock and nobody had wet feet!
The flat bottom foam makes for a very stable platform due to the wide footprint.
Barrels would kinda be like a ladies high heel shoe, ie sink 'till you get to the wide part.
   / Where to find info on building a pier/boat dock #19
Blue 55gal plastic drums using stainless steels strapping work very well as pontoons each drum should safely carry 225 pound @ 50% flotation.
same principle as below
   / Where to find info on building a pier/boat dock #20
Around here piers or pylons are driven in with excavators with cup arrangement on a rock breaker, this vibrates them in very easily with no damage that you get when hammered in.
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
2006 Toyota 7FGU60 11,250lb Propane Forklift (A55973)
2006 Toyota 7FGU60...
2018 KENWORTH T800 HOTOILER (A58214)
2018 KENWORTH T800...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
1111-A (A54756)
1111-A (A54756)
