where to find chainsaw blade for a stringtrimmer
   / where to find chainsaw blade for a stringtrimmer #1
dukenyc
Upstate NY
JD 4100
In a previous post we discussed using a device called a beaver-blade on a string-trimmer for cutting brush. The beaverblade uses an actual chainsaw chain on a disk. Someone else used a disk with chainsaw like teeth cut into the metal.
This is what I am looking for, the type with the teeth being part of the metal, not a separate chain. Does anyone know the name of these blades, or Know of a source where I can find one?
Thank you for the help.
   / where to find chainsaw blade for a stringtrimmer #2
I bought the circle saw type blade from the Stihl dealer where I got the string trimmer. Later I bought a Beaver Blade from Country Home Products where I got the DR mower/trimmer.
   / where to find chainsaw blade for a stringtrimmer #3
Your best bet would be the dealer that you bought it from. They could fit it with the right size blade. If you got it at a box store, the first question should be, "can it run a blade?" Smaller trimmers are just that, trimmers. Even larger trimmers that are not commericial cant handle ALL blades.
If you got it at a box store, try hitting up Yahoo with the make and model of your trimmer. See if they make the type of blade that you want.
   / where to find chainsaw blade for a stringtrimmer #4
I have both, and either type will work pretty well for small brush and trees up to 1-2" diameter.
Bought mine at my Stihl dealer, but there are smaller size trimmers that are not recommended for saw blades.
What trimmer do you have?
   / where to find chainsaw blade for a stringtrimmer #5
duke,
I've got one and don't use it too much. I don't like how it grabs and it takes some work to get though larger brush. They bounce off sometimes....haven't used mine in a couple of years.
I do like the blades that are made of steel and have about 5 sharp "wedges" on them. They cut through anything within reason and are much better at cutting brush. They're made out of the same material (steel) but there's only a few big cutting edges, not 40 or more. They are far superior at cutting brush IMO. The box stores should have them and various independent dealers.
   / where to find chainsaw blade for a stringtrimmer #6
Beaver Blade. Round disc with a chainsaw chain attached.
Country home products sells them.
Phi
Never mind. I reread your post and you don't want this type.
LINCOLN PUSHMOWER (A58374)
LINCOLN PUSHMOWER...
LANDHONOR LHR0300 HD CONCRETE FLOOR SAW (A52708)
LANDHONOR LHR0300...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
Informational Lot - Shipping (A56436)
Informational Lot...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E50NKE58889, Super Cab, 4 x 4, 5.0 L V8 Gas Engine, (A59076)
2022 Ford F-150 XL...
BUSH HOG 14' ROTARY MOWER (A52708)
BUSH HOG 14'...
