where to find chainsaw blade for a stringtrimmer
   / where to find chainsaw blade for a stringtrimmer #1
dukenyc
Upstate NY
JD 4100
In a previous post we discussed using a device called a beaver-blade on a string-trimmer for cutting brush. The beaverblade uses an actual chainsaw chain on a disk. Someone else used a disk with chainsaw like teeth cut into the metal.
This is what I am looking for, the type with the teeth being part of the metal, not a separate chain. Does anyone know the name of these blades, or Know of a source where I can find one?
Thank you for the help.
   / where to find chainsaw blade for a stringtrimmer #2
I bought the circle saw type blade from the Stihl dealer where I got the string trimmer. Later I bought a Beaver Blade from Country Home Products where I got the DR mower/trimmer.
   / where to find chainsaw blade for a stringtrimmer #3
Your best bet would be the dealer that you bought it from. They could fit it with the right size blade. If you got it at a box store, the first question should be, "can it run a blade?" Smaller trimmers are just that, trimmers. Even larger trimmers that are not commericial cant handle ALL blades.
If you got it at a box store, try hitting up Yahoo with the make and model of your trimmer. See if they make the type of blade that you want.
   / where to find chainsaw blade for a stringtrimmer #4
I have both, and either type will work pretty well for small brush and trees up to 1-2" diameter.
Bought mine at my Stihl dealer, but there are smaller size trimmers that are not recommended for saw blades.
What trimmer do you have?
   / where to find chainsaw blade for a stringtrimmer #5
duke,
I've got one and don't use it too much. I don't like how it grabs and it takes some work to get though larger brush. They bounce off sometimes....haven't used mine in a couple of years.
I do like the blades that are made of steel and have about 5 sharp "wedges" on them. They cut through anything within reason and are much better at cutting brush. They're made out of the same material (steel) but there's only a few big cutting edges, not 40 or more. They are far superior at cutting brush IMO. The box stores should have them and various independent dealers.
   / where to find chainsaw blade for a stringtrimmer #6
Beaver Blade. Round disc with a chainsaw chain attached.
Country home products sells them.
Phi
Never mind. I reread your post and you don't want this type.
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
KUBOTA SVL 75-3 SKID STEER (A52709)
KUBOTA SVL 75-3...
2024 RAM 3500 CAB & CHASSIS (A59575)
2024 RAM 3500 CAB...
PORTABLE AIR COMPRESSOR W/ GAS MOTOR (A58374)
PORTABLE AIR...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
