Where to find a Kverneland Y flail
   / Where to find a Kverneland Y flail #1
Brewsky
Falls Creek, PA
Branson 4220i, Ford 1520, MF 1710 TLB
I picked up a decent, but old, Kverneland FL150 flail mower. After the usual amount of TLC, I have been able to use with good results in areas I would like a better cut than with the bush hog. Inspecting it after use today I found a couple flails (Y type) missing. Not surprisingly, I have not been able to find a source for the flails. It is 4-13/16" long, 1-3/16" wide with a 3/8" hole and is attached with a clevis arrangement between two lugs on the shaft. (photo attached). I found a very similar flail in the Mott EF386, but the dimensions are not quite a match. Any ideas on a replacement source? Thanks for your help.
   / Where to find a Kverneland Y flail #2
How are folks going to help you locate parts if you don't state where YOU are? :oops:
I've never heard of the Kverneland mowers so I looked it up. Apparently, they are only available in the U.K. I was going to point you to where I get my spoon knives. They show something close to your side cutters but if you're in the U.K. that won't help much.
Here's the link any way; Clean Cutter Side Slicers
Look about midway on the left side of the page.
Good point as to my location-thanks. I'm in W Central PA. I tracked down some U.K. sources as well, but the specs were not quite a match. I'll check on your suggested source. Thanks again
   / Where to find a Kverneland Y flail #4
That looks and measures out to be almost exactly the same as those used on Alamo/Mott fine cut flails. Check it against the measurements given in the Flailmasters catalog and see if you do not agree.
Thanks John0829, I have found a Mott flail to be very close. I'm going to try to order one from the vendor Tinhack suggested for comparison next week and will advise the results.
UNUSED FUTURE 24" CAT 305 EXCAVATOR BUCKET (A57193)
UNUSED FUTURE 24"...
LANDHONOR BS-12-2500G (2) PRONG HAYSPEAR (A57193)
LANDHONOR...
2018 Genie GS-1930 19ft Electric Scissor Lift (A55851)
2018 Genie GS-1930...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2012 BOBCAT T770 SKID STEER (A52707)
2012 BOBCAT T770...
(2) UNUSED 18.4-30 TRACTOR TIRES (A57192)
(2) UNUSED 18.4-30...
