Where to find a Kverneland Y flail
   / Where to find a Kverneland Y flail #1
Brewsky
Falls Creek, PA
Branson 4220i, Ford 1520, MF 1710 TLB
I picked up a decent, but old, Kverneland FL150 flail mower. After the usual amount of TLC, I have been able to use with good results in areas I would like a better cut than with the bush hog. Inspecting it after use today I found a couple flails (Y type) missing. Not surprisingly, I have not been able to find a source for the flails. It is 4-13/16" long, 1-3/16" wide with a 3/8" hole and is attached with a clevis arrangement between two lugs on the shaft. (photo attached). I found a very similar flail in the Mott EF386, but the dimensions are not quite a match. Any ideas on a replacement source? Thanks for your help.
   / Where to find a Kverneland Y flail #2
How are folks going to help you locate parts if you don't state where YOU are? :oops:
I've never heard of the Kverneland mowers so I looked it up. Apparently, they are only available in the U.K. I was going to point you to where I get my spoon knives. They show something close to your side cutters but if you're in the U.K. that won't help much.
Here's the link any way; Clean Cutter Side Slicers
Look about midway on the left side of the page.
Good point as to my location-thanks. I'm in W Central PA. I tracked down some U.K. sources as well, but the specs were not quite a match. I'll check on your suggested source. Thanks again
   / Where to find a Kverneland Y flail #4
That looks and measures out to be almost exactly the same as those used on Alamo/Mott fine cut flails. Check it against the measurements given in the Flailmasters catalog and see if you do not agree.
Thanks John0829, I have found a Mott flail to be very close. I'm going to try to order one from the vendor Tinhack suggested for comparison next week and will advise the results.
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
Blue Diamond 103709 (A53317)
Blue Diamond...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
