Where to Buy Best Battery?
   / Where to Buy Best Battery? #21
Wirehead
:welcome: to TBN
Model number?
Or part number?
After many years, my X485 battery failed... bought the X485 spring 2003.
   / Where to Buy Best Battery? #22
Thanks for the welcome Beenthere. Who makes the x485.
   / Where to Buy Best Battery? #23
For my JD 790, I would like to get a good solid non-oem battery. I have read that Optima makes a fine yellow top. Any recommendations? Best prices?
Thanks.
Optima is an AGM. I use a red top in my WRX because it is 12 lbs lighter.
I consider the Odyssey AGM to be the absolute best available. It is also sold as the Sears Platinum.
ODYSSEY battery - Official Manufacturer's Site
   / Where to Buy Best Battery? #25
John Deere as listed under profile.
In your first post you asked..
but does anyone have a model number for the 790 battery?
What do you mean by a "model number" ?
   / Where to Buy Best Battery? #26
I agree with the above.^^^^
I have had the Odyssey batteries for several years and are my favorite. They hold a charge without the need of a trickle charger all year. For the vehicles with every day use I have the Walmart Everstart Max, since these stores are everywhere service is close and most are less than $80 for a 6 year battery. With about 25 batteries to maintain I can't afford to have all Odyssey batteries and not all sizes are available. Sears Diehard Platinum are Odyssey batteries but are only available in about 2 or 3 sizes.
   / Where to Buy Best Battery? #27
Can't speak for all Walmarts- but ours sold Exide sourced batteries and personally had many of the ones I purchased fail within 3 years, a while back noticed that Johnson Controls was producing batteries for Walmart, same supplier for Les Schwab tire stores (north west US) and they have been very reliable, So have purchased a couple lately from Walmart and so far so good..
   / Where to Buy Best Battery? #28
Battery brands sometines change suppliers and sometines have multiple suppliers.
The most basic quality gage is the length of 100% replacement.
   / Where to Buy Best Battery? #29
I agree with the 100% replacement, and find if they last this long without failure they will usually make if for the full life of the specs. I find that all most all brands of the starting batteries seem to be good enough these days. I do prefer to have a better quality battery for deep cycle and marine uses though.
   / Where to Buy Best Battery? #30
Maybe not the best brand, but I got a Advance Auto Marine Starting battery for my 861 Diesel this past Spring. I read the Marine batteries were a little more robust than standard car batteries (they stand up to wave bouncing boat hulls) and this one had 800 CCA and was cheaper than a similar car battery with the same CCAs. It also has 2 extra connection terminals with a nut I can used if needed for accessories. So far, it has worked great, but I haven't had to use it in cold weather yet; time will tell.
INFLATABLE BOAT & TRAILER (A52708)
INFLATABLE BOAT &...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Year: 2018 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 67,012 Plate: Body Type: 4 (A56858)
Year: 2018 Make...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
GALVANIZED WATER TROUGH (A52708)
GALVANIZED WATER...
